its my second Benz its a 1988 420sel gold and tan
hi i want to change my door speakers in my 201, does anyone know what size they are ?? secondly how do i remove them do I have to remove the entire panel >>>?? thanks for any help
1985 190E 2.3 (Sold)
The door speakers are 4" I believe.
To remove the door panels....undo the plastic door lock pull up pin, the plastic door latch cover screw on the side of door where the catch is, then carefully pry off the interior door handle trim piece that surrounds the door handle, then unbolt the arm rest and disengage the door latch rod by sliding the trim piece with the door handle out. Then you lift the panel to disengage the glued on hooks that hold the panel to the door. Be careful not to tear the plastic moisture barrier. If you do, you can easily replace it with plastic sheeting and some trim adhesive. Before you can get it all off, unplug the window lift electrical connector on the backside. Then door panel comes off. If you rip off any of thoe plastic hooks, you can easily glue them back on with hot glue.
