Ugh, it's not easy...
Anyone know how to take off the door panel? front and back door.. my doorpin was broke and i need to fix it fast.. please helllppp!!! any picture will be helpful also.. [?][?][V][V][?][?]
thank you.. [
I've removed mine several times and it's not exactly the easiest. You will have to first remove the front "cover" of the door handle by slowly prying it off at the base using a slotted screwdriver. After that comes out, you will need to remove both screws located in the handle. Next, remove the SRS badge and remove the screw behind there (it's a torx bit, IIRC).
Once you have removed the tools, here comes the tricky part. Be sure to roll down your window!
You will need to pull the door panel outwards, starting from the sides and working your way down. A trim removal tool (I used a Snap-On snake's tongue tool) really helps here. After that, you will need to pull up the horizontal surface of the door panel and work it out of the window seal. Basically you will have to use your fingernails and pull it upwards. Once that is done, you can lift the door panel upwards off the seal, and then outwards.
If you have any questions, feel free to ask [
