The CLK is really annoying. I would suggest you get someone to show you the first time. Even if you do get the screws (behind SRS) behind handle then unclipping the bottom and lifting up gently.irfanh - 4/13/2005 10:59 AM
I have a 2001 CLK, I want to upgrade my door panel speakers and put in some sound insulation if possible.
Any ideas or links on the correct way to remove the door panels for access to these areas?[]
