ML 320
What is the name for the white door panel snaps that hold together the door paneling? The white snaps have started to break on the side passenger door and now the door panel is hanging off/ misaligned with the passenger airbag. What are these things called? Where can I buy them? How much do they cost?
Thank you!
1999 Ml430
Very easy... the flat side of the clip actually doesn't snap in they just slide into black holders attached to the door paneling. I had to epoxy two of them back in because the original glue was all dried out and they got loose.. all I did then was hooked the panel back into the top side pushed it against the door and with a couple of blows with the hand they all snapped back in.
