1 - 20 of 34 Posts
2002 E55 AMG Obsidian Black with Charcoal
I purchased a set from another internet site in Asia. Not the link in my initial post.
This second place had two different gaskets/seals.
W210 1995-1999 and a different part for W210 2000-2002
Waiting for the items to arrive...probably by sea going vessel.
I plan on making a full write up with comparison pictures. I'll post the source then also.
2002 E55 AMG Sedan
I too am curious. Both my driver and passenger door mirrors gaskets are pretty well crapped out :-|
1999 E55
Hi guys just joined this site and have just bought a 1999 E55 and am fixing a few things at the moment and these side mirror rubbers are on the to do list. Can't wait for the update on the aftermarket ones to see if they fit as will order some also, cheers..
Discussion Starter · #10 · (Edited)
Today I installed the new gaskets/seals. I am very satisfied. They fit and look fantastic. I recommend them.
Pictures are attached.
Below is my correspondence with the company I found on the internet. I e-mailed with someone named Rock Wu. Fong Mei Trading Co., Ltd. is located in Taiwan.
Click here for the web site link W210 Power mirror rubber pad - Fong Mei Trading Co., Ltd.
The gaskets are very close in appearance to the originals. You will not see the differences once the gaskets/seals are installed.
Dear Sir,
We thank you for your e-mail and inquiry.
The 1995-1999 E Class door mirrors are different then 2000-2002
1995-1999 E Class →Product number: HGB6004
After 2000 E Class →Product number: HGB6039
(1) HGB6039(W210 Power mirror rubber pad)
Price as below
Unit price: US$45.00 X 1 Pack= US$45.00
Shipping cost: EMS US$18.00
Total US$63.00
(2) We can accept payment by Paypal.
Paypal account: [email protected]
(3) shipment by EMS(Post Office) need to take 5-7 days for delivery
(4) Dispatch goods Immediately as soon as receive of your Paypal payment.
We look forward to hearing from you soon
Rock Wu
BENZ - Fong Mei Trading Co., Ltd.
2014-03-28 0:38 GMT+08:00 [email protected] <[email protected]
Question from website about product : W210 Power mirror rubber pad
First and last name : Ola
Company :
Country : United States
Telephone :
E-mail : [email protected]
Your question
Does this item fit the 2000-2002 W210 E Class cars? The 1995-1999 E Class door mirrors are different then the 2000-2002. I am interested in purchasing these.
-- Fong Mei Trading Co., Ltd. 宏美貿易有限公司 - [email protected]
No.618, Yu Yi Rd., East Dist, Tainan City 70163, Taiwan (R.O.C.)
Best Regards
宏美貿易有限会社
吳 文仁 Rock Wu
Tel:+886-6-3314596
Fax:+886-6-3319225
E-mail:[email protected]
Website:BENZ - Fong Mei Trading Co., Ltd.
Address:No. 618 Yu-I Road, East Dist., Tainan City,Taiwan(R.O.C)
skype:rocker8756411
Discussion Starter · #11 · (Edited)
Drive 1
Pictures of my original gaskets/seals. They are dry rotting. Having spent its life in (dry climate) Arizona and the last 4 years in Miami, Florida.
Driver's side top, front, and rear had broken off. I was getting noticeable wind noise when I was driving.
I did not indicate how to remove the housing cover. You can search for that, or just ask.
Picture 4 shows the new gasket/seal.
Easy to remove the black and white electric plugs.
Discussion Starter · #13 · (Edited)
Drive 3
The 2 and 3 pictures shows the old gasket next to the new one.
Note: There are slight differences.
The middle hole, the one recessed for the wire harness, is not punched out nor a molded nipple.
The lower molded hole for the wire harness screw is in the wrong location. Both items are not a big deal. I cut the old gasket with a razor blade to gently remove the wire harness. (see the passenger side pictures)
Follow along to see my solution....
Discussion Starter · #14 · (Edited)
Drive 4
The 1 picture indicates where the wire harness screw should be located. I just cut an X with a razor blade large enough for a small screw to be pushed through. The larger defined oval shape is where I cut a larger X for the wire harness to be pushed through. Be sure to push it through from the correct side.
Pictures 2 and 3 as you can see, I gently pushed the wire harness through.
Discussion Starter · #15 · (Edited)
Drive 5
I used some black automotive gasket sealer for the newly cut holes. The unused molded wire harness screw area was sealed with gasket sealer also. Just incase of rogue water trying to find it's way in.
A little sealer goes a long way. Do not over squeeze. Just a little to seal the holes.
Discussion Starter · #16 · (Edited)
Drive 6
Reconnect the wire harness to the body. Install the three screws.
Don't forget to reset the metal spring that holds the cover on. (Just pry it out - forward- a little)
I had the blinker on and gently slid the outer cover back onto the mirror housing. It seats itself and locks back onto that metal spring clip that you just reset.
I have the blinker on so I can see that the turn signal does indeed work after I reseat the cover.
The last few pictures show the new gasket/seal installed. Very nice.
The whole job took about 15 minutes for this side.
Now onto the passenger side.....
Discussion Starter · #20 · (Edited)
Pass 4
I cut the old gasket/seal to pull the wire harness out.
Picture 3 and 4 show the old and new gasket/seal next to each other.
1 - 20 of 34 Posts
