Door lock cycles--how many before it runs out of puff?
  • 1
    Votes: 4 22.2%
  • 2
    Votes: 1 5.6%
  • 3
    Votes: 1 5.6%
  • 4
    Votes: 1 5.6%
  • 5
    Votes: 6 33.3%
  • 6
    Votes: 0 0.0%
  • 7
    Votes: 1 5.6%
  • 8
    Votes: 2 11.1%
  • 9
    Votes: 0 0.0%
  • 10 and above
    Votes: 2 11.1%
1 - 20 of 23 Posts
W-1-2-3 Go!
How many cycles does your W123 have before your vacuum door locks run out of air? Lock/unlock is one cycle. Mine can do roughly 5, but at the 5th it's really sloooooow...
1990 300SE, 1983 300D
Mines around 4 I think. I gotta double check. [:I]
1984 300CD
I'm up to about 25 and I'm getting tired....uh...oh...duh...am I supposed to turn the engine off to check this [?][:eek:)][:eek:)][8D]
W-1-2-3 Go!
MBZ300CD - 2/8/2005 8:47 PM
There's no way you posted that without something nice happening to you! Cmon, let us in on it! [:D][:D]
W-1-2-3 Go!
Schmohey - 2/8/2005 7:24 PM
The manual said 5, but I never actually tried it.
On my manual it says you can lock/unlock it 10 times! [:0]
On a side note, what is the volume of the vacuum reservoir? Does anybody know?
1982 280E
Mine only does one, or if I wait too long after switching off the engine it doesn't lock at all[:(][V]. I know, I need to start looking for a leak somewhere.
I can hear a humming sound which I'm pretty sure is the leak somewhere close to the ignition key area. Are there any vacuum connections behind the dash that may be causing my leak?
BTW, it's a 1982 280E with manual A/C. So there should not be too much vacuum controlled automatic climate control stuff behind the dash??
1984 300CD
I tried this when I got to work just now...had to get into the office and didn't want to start the car to lock it again so I stopped @ 8 times and going strong.[:p]
[8D]
1984 300CD
OK for the record, I just did it till it would go no more...15 cycles...but then I do have a two door advantage. [8D]
1984 300CD
karugs - 2/9/2005 6:45 PM
What coupe has the 15 cycle limit, the black or green/blue?
The New Blue, the Black is good for about 3. [8D]
1991 300 SE
I used to get 10 or so but the vacuum’s bad and it will only lock once right after the engine’s off. Since the engine shuts off right away, the transmission shifts smoothly, and the locks work with the engine on I’m assuming he egg crate is bad. [:(]
1980 300TD
I said 1, but really you need a zero option :)
My tailgate never locks, and the others only go if you lock it right after you shut off the motor, just like Henk's.
2005 w203, 2013 Town & Country
mine will go until the battery dies...
electric conversion
jake
'81 300TD Turbo
BF_JC230 - 2/10/2005 7:25 PM
electric conversion
jake
There's always one... [}:)]
W-1-2-3 Go!
Discussion Starter #16
ndcv - 2/9/2005 9:28 PM
Sorry, I forgot! [:eek:)]
JDC, how can the egg crate go bad? Isn't that just made of plastic?
Here's an idea, is it possible to install larger vacuum containers to provide a larger reservoir (and more lock cycles)??
1995 E320 Sportline W124
jdc1244a - 2/9/2005 11:22 PM
I replace the egg crate a year ago, and since then I can score 10 on all doors, fuel plate and trunk.[^]
2008 PT, 1998 neon--1965 VW 1200
it went 6 locks, but then wouldnt complete the unlock that time. or vise-versa. not sure how to count them[:)]
i thought the car was kind of shabby by comparison. yours all look so shiny and all, but i guess its about on-par, eh? do we(the majority of those polled) all have wonderful cars? or do we all have mediocrity?
no offenses meant, just curious, really. how many of youall have replaced/rebuilt the vacuum systems?
this has me wondering about if i chased down all the leaks! i might not need a vacuum system rebuild afterall(but prolly do anyway, im terribly unlucky)
1 - 20 of 23 Posts
