'95 500SL R-129 - '96 500SL R-129 - '98 ML320 - '98 CLK320
I have seen a similar issue online, but no specific resolution.
symptoms:
1-open drivers door, lamp does not light on the door panel or overhead if switched on.
(when passenger door is open, all lights light up)
2-power seats on drivers side will not work unless car is switched on.
3-radio not working.
(with headlights on, radio has a dim light when powered, but will not work or put up the antenna when switched on)
The brake lamp switch was recently changed and the dealership, but I would like to see if there is perhaps a relay, or something that is not getting power as a result, before I take it to the stealer and get a run around. It was all working fine before it went in.
All fuses appear to be in working condition..
Any help would be greatly appreciated.
2005 SLK350, 91 300SL with Pano Top, 04 S500, 2015 Tesla Model S
Sound like a missing ground wire problem that got introduced when that switch was replaced.
Turns out the alpine radio was shot, so I picked one used on ebay. The other symptoms remain-Its just to cold to get in there and open it up to check ground connections.
symptoms:
Moderator
SL55, 300SE, GL450, Daytona 955i
You have a blown up relay box behind the passenger airbag.
Search again, but use my username in your search for poster, you ll find a post from few months ago about this...
