1990 Mercedes Benz 300e
Hey im stuck. i am trying to remove my door to put on a new one. I have followed all the steps that i've seen online. This one hinge won't budge. i tried hitting up from the bottom with a hammer and such. Any ideas? Thank you.
About a dozen 1988, 1989, 1990, and 1991 sedans, wagons, 4Matics and 1 coupe
Uh, it's not a hinge. It's the door check strap, the thing that keeps the door halfway and all the way open.
There's an e-clip snapped to the bottom end of the pin and you have to remove that before you can drive the pin upward. Also, there's a small plastic washer/spacer between the top of the strap and the mounting ear. I can see it in the picture anddon't lose it.
BTW, the very top of the pin shank is splined to make it stay tight. You do have to give the bottom a bit of a whack to overcome that.
