2000 E320 Sedan V6 3.2L 5-speed Automatic
Hello guys, I into fixing my dome lights. The rear dome light is working perfectly fine, even turns on when door opens. The rest of the interior lights are working good too except for the driver and passenger dome light as well as both visors lights. What could be the problem??? I can operate the sun roof and the rear dome light. The bulb for the front dome lights looks good, i guess there is no power reaching then. Will replacing the console fix the problem?
1997 Mercedes Benz E320
Check the fuse first. What may seem like a project that will end in big bucks might only cost a few dollars instead.
W210 Moderator
99 E320
dont look at the bulb and assume that it is intact. measure it (continuity check)
while you're at it, use volt meter to the bulb holders to verify voltage
yes, check fuse (also, don't look but verify using continuity reader)
absent a volt/ohm meter, remove bulb and swap out with another socket using same bulb size to test
