1991 300e 3.0:
Gents,
Does this pictured loose/dislodged pin and washer mean that the brake booster is broken?
Or can I put the pin back in place and properly seat the master cylinder onto it?
Thank you,
Sev
Discussion Starter #2
Background:
Last week, I went to replace a bad master cylinder, and brake fluid flush
When I put the new M/C in place, at first it wouldn't bolt up
Then I jiggled it a little, and nested it into the booster
as I tightened it, I heard a 'clunk', which to me meant it was now seated in place.
fast forward to today
I am going to do a two-man brake fluid flush
I try flushing from the rear right caliper first, working my way to the front.
Fluid is not coming out the nipple
I decide to first flush the new master cylinder.
The rear line flushes properly
The front line...no fluid going through
I thought maybe bad M/C again.
So I remove the master cylinder to bench test it
Then I see the attached pin and "washer" (for lack of a better term)
loose inside the booster
Perhaps the clunk I heard dis-lodged this pin and washer
Current, 90 300CE, 92 400E (Sold 95 E320,70 250C, 91 190 2.6, 91 420 SEL, 95 300D, 87 TD)
Bump
I have never done this job......yet:unsure:.
But hopefully someone will answer.
I know someone knows!
