2007 CLK350
The “B” Camshaft Position fault code P0015 used to be pending a couple weeks ago. It’s turned into current now. My check engine light was on this morning, and it disappeared on the way back home from work. Is this a very serious/urgent problem?
No, nothing terrible will happen. YOu'll lose some power and probably MPG, but that's about it. The good news is that if you can turn a wrench, it's an easy and fairly cheap repair. All four solenoids can be bought for about $100 total. All but the right exhaust are an easy three-bolt job. That one usually requires removing the oil cooler, so you have to drain the radiator, and should probably replace the oil cooler gasket when it's removed.
2008 AMG CLK63 Conv., 2012 R350 4-Matic, Wife's 2015 C300 sedan
Camshaft position sensors are easy and not very expensive to replace.
