1995 Mercedes-Benz S420 (W140), 1997 BMW 740iL (E38), 2011 C300 Luxury (W204)
Does the duo valve stay on when you turn off the car? I still hear it buzzing quietly sometimes. When I unplug the plug in the picture, it stops (well obviously), but I'm not sure if it's suppose to. I'm having issues with my duovalve so I'm just curious.
1989 190e 2.6 1993 500sel (sold) 1995 S500 coupe (sold) 1994 S500 blk/blk
No, the duo valve shuts down when ignition is turned off; however. there is an auxiliary water pump that is a part of the duo valve component that may continue to run for a short time, depending on the high temperature of the coolant. This information applies to
the S500, but may be different from your 420, but I doubt it. The picture that you show is the auxiliary water pump.
2016 E350 4matic Luxury Sedan, 2011 E350 Avant Garde Cabriolet
I went through the same questions when I first got my W140. It's the aux. water pump and it runs after you shut the key off to cool the engine. It should shut off after a certain time (not sure how long).
Its normal
You're right. I meant that pump but said duo valve since they're all together. I guess it makes sense it stays on when car is still hot. My guess is it stops at a certain temp.
I just ordered a new unit, I hope that's my problem. I can't confirm that I have stuck valves which causes my side vents to blow hot air until the new unit arrives so I could open and examine the old part.
I've gotten error codes for short/open circuit in the valves and the pump as well as pump being overloaded and aux fan short/open circuits. Quick look at the wiring and it seemed fine with no insulation issues like the engine harness. I will look harder and trace it later. I'm afraid the wires are part of the huge body harness...
