1 - 9 of 9 Posts
1989 Mercedes Benz 190E
Hi
so ive been trying to figure out why my car wont start:(
i was looking at my fuse cover and it says Automatic Solenoid fuse 1....is this true? the automatic cars have a fuse for the starter? what is this? the problem is my car wont start..when i put it in on postion i hear the fuel pump buzzing, and when i go to start the car..i can hear the starter moving but not engaging and turning the car over...any help? :confused:
the dude i got the car from had wrapped a few ceramic fuses in tin foil..in particular one piece of foil had that burnt look to it...any idea why my car wont start?
'01 SLK230,'93 190E 2.3, 1971 LS5 Corvette Convertible
Before you start drinking any Rum or Grey Goose, I would first replace all of those foil covered fuses.
In my 25 years of owning MB's every time the engine wouldn't turn over it was due to a bad battery. They just go out without warning. My indy friend insists on replacing them every 4 years.
The only time is wasn't a battery was on the 190 2 years ago. It turned out to be a defective starter. Replaced it with a rebuilt Bosch and no problems since.
· IR MODERATOR
1996 Volvo 855GLT, 1993 MB 190e 2.3 8v, 1998 Subaru Outback SUS, 1991 BMW 525, 1998 MB C230
fix the fuses and then check the started solenoid wire that is on the firewall near the brake booster
hey i got the fuses today and will change them..also i dont have a new battery..but i have battery jump pack the portable one.. ill use that... would you happen to know the fuse diagram for a 2.6 1989 nam version 190E? it has a sunroof aswell...
'92 MB W201 2.3, '10 MB X164 GL550 4Matic, '14 MB W218 CLS550 4Matic
No hard feelings buddy... but get a Ford Escort :p (just kidding) as you need to work out many things on your benz
I'm sorry that you couldn't resolve the starter issue though it took two threads up to now
As always, I would highly recommend downloading the W201 manual from the FAQ section of this forum..it will teach alot and your are always welcome to ask overhere but you need to do your homework too
· IR MODERATOR
check what? if its burned out"? or ? its an 89 190E 2.6 NAM what does the wire look like??
theres a single pin connector with a purple wire on it that goes from the ign switch to the soloniod, chaec to see if the wire is connected adn not corroded and broken. its near the top of the firewall behind the brake booster.
Reactions: Jacques405
Discussion Starter · #8 ·
im at work right now, will check it this evening ... thanks for your help!!
Discussion Starter · #9 ·
i downloaded it but couldnt make sense of it, i will look at it again. sorry for the trouble
1 - 9 of 9 Posts
