So I've had a leak for a while and now it started to get worse, I decided to look and see where it's leaking from. I figured it would be from the valve cover gasket because the head gasket has been replaced not too long age and there's oil right under the valve cover
I open my hood and i find this:
The engine is cracked from the bolt to the left as you see
Any solutions for that other than replacing the entire engine?
The engine has 139k on it
Thank you
Thank you
