92 400SE, 93 400E, 01 CLK320, 01 ML320, 98 Land Rover Discovery
My MB has the 722.3. Is your a 722.6? If you're a moderate DIYer... the job isn't very d...
My MB has the 722.3. Is your a 722.6? If you're a moderate DIYer... the job isn't very difficult to replace the AT fluid, AT filter and AT pan gasket. I listed the MB transmission fluids below. I use the MB fluid from the dealer. My trans uses 7.7 Liters 8.1 Quarts for a complete change. How many mile on your tranny?
AUTOMATIC TRANSMISSION FLUID
For MB automatic transmission (not including MB automatic transmission W5A580, model 722.6), transfer case (4MATIC), and MB manual transmission (except GL76/30-5 and GL275E) use:
Castrol Dexron-III/Mercon ATF F-30341
Castrol Transmax M-22257 / 22096
Chevron ATF Dexron III F-30108 / 30159
Citgo Multi-Purpose ATF D-21571
Exxon Superflo ATF Dexron-III F-30111
Havoline ATF Mercon/Dexron-III F-30321
Pennzoil, ATF D-21380
Pennzoil, ATF F-30110
Quaker State Dexron-III/Mercon F-30161
Sunoco ATF Dexron-III/Mercon F-30176
Texaco ATF Mercon/Dexron-III F-30321
Unocal Multi-Purpose ATF D-22413 / 22431
Valvoline ATF Type D
Supplier Information:
Castrol, Piscataway, NJ / Toronto, Canada
Chevron Products Co., San Francisco CA
Citgo Petroleum Corp., Tulsa, OK
Exxon Company USA, Houston, TX
Texaco Lubricants Co., Houston, TX
Pennzoil Products Co., Houston, TX
Quaker State, Seneca, PA
Sun Co., Philadelphia, PA
Unocal Science and Technology Div., Brea, CA
Valvoline International, Lexington, KY
For MB automatic transmission W5A580, model 722.6 and Model 163 transfer case use:
MB Automatic Transmission Fluid MB part no. 001 989 21 03 10
