1 - 9 of 9 Posts
1997 S420, 2000 E55
It seems the extraction method can be kind of hit or miss with some vehicles. It seemed to work well with my W140 but not my S2000.
I have read a couple of posts where a Top-Sider has worked well, but nothing to confirm that it does as well or better than a traditional drain.
thanks for any input.
1997 S420, 2000 E55
Alabasi - thanks for the input. What model do you use?
Is there any difference in performance among the units? Does one have better transporting spent oil to recycling over the other?
1972 280CE
Hi, I have this one: Pneumatic Oil Extractor
It uses an air compressor to create a vacuum that sucks the oil out. I've not use any other one, but this one seems to work pretty well. You need to pull a vacuum a couple of times, but that's a small price to pay considering that I can now change oil in a white linen suit :)
You have to manually drain it. I have a couple of 2.5 gallon jugs that I usually use for transporting but this time, a buddy of mine stopped by with his 82 Mercedes Benz 300SD and dumped the contents of the container into his fuel tank.
Mercedes dealer's use pneumatic top sider's - just remember two things:
1) You have a 8 1/2 qts to pull out so get sufficient capacity
2) hand vacuum units do work well - but it takes a bit of time - like 10 minutes - and a couple of added pumps to keep a good flow
1997 S420, 2000 E55
8.5 QTS? WIS and AllData both show 8 quarts w/ filter change.
EDIT: Strike that. It is 8Liters which is approx 8.5 quarts.
2002 AMG E55, 1997 E320
I use the Mityvac 7201. It works great - very easy to use. I extract my oil from the engine then pump the old oil into my 2 1/2 gal can and take it to the recycler. Extraction takes about 10 mins, during that time I prepare the new oil filer and O rings, get my new 8+ qts of oil ready and check tire pressure, etc. Very clean and simple. :thumbsup:
2009 E63, 2000 ML430
I use one I bought of ebay. Works fine. Use it for the E55 and our R350. The R has a HUGE piece of plastic under it with about 12 mounting tabs.
1 - 9 of 9 Posts
