1 way trip of 5 Miles.
Once or twice a month it is a one way 10 mile trip to Mom's House.
Since I was Injured it has become my Daily Driver because it is what I can fit into easily.
So It does not go far from home.
However, If you are trying to find out what type of Repairs you might be facing it would be better to ask what people have done every year they have owned the Car.
I have owned the Car for 4 years now.
Certain things like last year when the B2 Piston in my Transmission Finally broke and after starting that repair I moved on to the Drive Shaft U-joint Repair grounded the Car for 3 Months. So it is a Daily Driver as long as I have the Parts, Tools and Knowledge to keep it going (I also rebuilt the Brake Calipers that year).
I am not sure if I replaced the Turbo Drain Seals at the begin of this year or last Year.
The first year of owning the Car was about Brake pads, rebuilt Master Cylinder, replacing
the rear Axles with rebuilt ones due to ripped Rubber Boots and I think I did my first Valve Adjustment. I also rebuilt the Injectors, replaced the Motor and Transmission Mounts.
2nd year owned I changed the Oil Cooler Hoses, the rebuilt Master Cylinder went bad and I installed a actual new one.
Finally got a Drip Tube and did the Fuel Injection Pump Timing.
Not sure what year I did this but I hit an Island and tore up a Rear Trailing Arm and dented the Wheels. I replaced those with used ones.
Year 3 I replaced the Transmission Cooler Hoses.
Not sure if this happened at the end of Year 2 or the begin of year 3 but my Lower Control Arm Bushings finished rotting out and it only took 3 days for my Tires to start getting eaten up.
I had neither the Klann ($365) or Klann Clone Spring Compressor(about $180+ shipping) for the front Springs.
Two attempts to use the cheapie Strut Type Spring Compressors resulted in them getting bent up.
I ended up making my own Spring Compressor for the job. And, the Job did not go well. One of the Lower Control arm Bolts was rusted to the Bushing Sleeve.
(I bought a complete Cheapie front End Parts Kit and also replaced the Upper Control Arms.)
I actually did the Lower Control Arm Bushings again because the bores of the Lower Control Arms were so badly Scaled with Rust that after cleaning them the Hole was in larged. I had to get the Car going so I installed the Bushings anyway and got the Car on the Road.
I got another set of Lower Control Arms off of eBay and re-did the Job with new Control Arm Bushings.
So approximately each Year of ownership have been marked by some repair issue that has made the vehicle un-drivable for extended periods of time.
So I do not see how any one has only a Mercedes as the only Vehicle to get them to work unless they have another means to get them to work when the Mercedes is not going.
Also I could not remember everything that I have done and I did not include Filter Changes and normal maint stuff; I do a Valve adjustment once a year.
Kind of add up what the major repair stuff I did would have cost if I had paid someone.
