1 - 18 of 18 Posts
95,94for sale, 93 e320/300e, 06 s500 4matic
replaced bent rims with a staggered set17x7.5/8.5 30/37 et 225/45/17 tires
I got a fender roller coming in the mail but I thought this setup would fit more comfortable
W163 and General M Gremlin
Side profile p0rn pics please.
I'd add a DIY fender spacer kit on the front fenders too. I made ones 1" thick.
I have to make another set soon for the 420e.
But if you do this, as other posters have never elaborated the full monty of what you should do when adding these spacers to have it look oem (otherwise it looks hokey imo):
  • inner liner needs to be widened at the outside edge due to gap - easily remedy ===> plastic weld a strip of PnP liner onto the edge
  • rocker cover skirt end needs to match the fender widening above and the end cap needs a gap filler ===. easily done
Just takes time and effort.
Font Plastic wrap Handwriting Jewellery Plastic
Test drive under all conditions to check for any rubbing, tire, wheel interference.
They look fine to me. 17s, imo are the max for combination of fit, ride and comfort.
Max tire width is 225* (215s would be better suited) for the front end.
*Note: not all tires have the same profile so fitment under the wheel well or close to, will depend on the tire brand.
An example here:
Moving Mt. Everest "just takes time and effort", too.
If that's too big a dream for you... that's ok. ;)
Discussion Starter · #8 ·
I got like no fender space on the rear. I gotta definitely roll the lips. Might need to pull the front fender about 1/4”. According to the search of everyone’s experience with this setup I thought it would fit 100 percent no modifications
P0rn pics to clarify "no fender space" please.
Tire specs?
Fine tune ride height with spring pads.
Check your springs pads and find out how many dimples.
Rears only have #1-3 (8mm 13mm 18mm)
Hoping your present rear spring pad is #1 or 2. Then you can increase to #3 = 5mm increase from #2.
This equates to approx. 10mm increase in height at the wheel well edge.
Front has #1-4. 8-23mm in 5mm increments.
W124 300E 12v 1992.
Ah, does this height look good to you or is there another reason for it? Maybe better handling for you at high speeds?
Discussion Starter · #16 ·
I rolled and pulled the lips out. Plenty of room now. For anyone doing a search in the future this wheel combo on a 124 isn’t perfect
1977 W123.123 1995 W124.034
Yeah those are definitely not ideal for a W124. I'm running the following setup with no rubbing and I'm lowered with H&R springs and Bilstein B8s
Front - 17 x 7.5", ET35 with 215/45ZR-17
Rear - 17 x 8.5", ET30 with 225/45ZR-17
Automotive parking light Automotive side marker light Tire Wheel Car
Tire Wheel Automotive side marker light Car Vehicle
1 - 18 of 18 Posts
