1 - 8 of 8 Posts
'06 SLR McLaren-Silver/Blk,'07 GL450 Silver/Blk & '07 S600 Sliver/Blk
Recently I had an opportunity to open up my ’07 S600 on a long, flat private road and was relatively pleased with the overall performance until the 600 bogged down at exactly 130 mph. Does anyone know if the 2007 S600’s have speed governors? If so, is this because of the speed rating of the “R” rated tire?
Thanks in advance for any input.
ML500/S550/M5
i would assume yes, that it's electronically governed, but that can be removed/changed. For some of the newer AMG models, Mercedes offers an expensive package to remove the electronic limiter from the factory.
As noted from the factory, speed-limited to 130mph
It's the tires.
Plenty of tuners available to de-limit to at least 188mph
93 500 sel - 95 s500
It's the tires.
188 MPH!!!!! :0 THATS LIKE 290ish KPH!!!!!! HOLLY FACK
I sent my ECU and TCU (engine and transmission modules) off to Renntech and had my horsepower increased and torque increased, as well as raised the high speed limit to 189 mph. I hooked it all back up today (only takes about 20 minutes). Mine is a 2007 S600 and the horsepower is now at around 620 and the torque is at 740 ft/lbs. This car is frightening it is so powerful. I highly recommend Renntech. It only took 3 days total of down time to get it done by using UPS. If you would like to do this mod, contact me and I can help guide anyone through the steps or give suggestions.
2003 s600, 2000 gs300
Did you do a dyno b4 and after modification? how much to do mod the ecu and tcu, i was thinking about doing it if worth it. u say 620hp at flywheel or rwhp? any other mods avail?
Zotye Auto 1.5T T600 2016
It's the tires.
But will they help with the repair bills this added torque will eventually cause?:eek: :)
They have two speed limiters. One is electronic and the other is the guy behind the wheel lol:rolleyes: :thumbsup:
1 - 8 of 8 Posts
