1 - 10 of 10 Posts
Artic White 1995 S420
I just turned the car off after I pulled the car in the garage, and I looked under the car and saw a leak! Im very lean so I was able to get under the car and touch the fluid. It was water so I was thinking water pump. The thing is from what I understand the pump is in the front of the car not the center, could it just be a hose come loose or is it the pump? the car runs normally but the check engine light is on and the led diognastic blinks 19 times!
1993 300SEL (Sold) 2007 X5
You really need to pressure test the system and see exactly where it's comming from. For example I had the same symptoms as you a leak from the left front (when your sitting in the car looking forward) and I'd replaced my pump about 13-14 months prior turned out to be the radiator so you really need to pressure test. The coolant can run over things and end up dripping onto the ground from a completely different place than where the actual leak is.
'14 E350, '07 CLK350, '01 SLK320
Were you using the A/C? Are you sure it just wasn't condensation draining from the evaporator?
1987 560SL - 1994 S420 - 2005 S55 AMG
True if it was water and not coolant.
Normally the coolant will feel slicker then water from the AC. If the car is not running hot I would guess it is AC condensation also. If you are running other than Mercedes coolant (the green or orange stuff) try laying a sheet of white paper under the car and note the color. Of course Mercedes brand coolant is clear so it will only help if you are using the other stuff.
1994 s320
Mine leaking as well ,but its coming from the Pump to Block area ,might be an
o-ring/gasket.
Discussion Starter · #7 ·
yeh its clear and the car runs at normal temp all the time, and it only leaks sometimes. Maybe its just me but the ASR has been clicking on alot! From what I hear thats another symptom of a coolent leak.
SL55, 300SE, GL450, Daytona 955i
where did u get this handy piece of information from?
SEC 600 V12 2dr COUPE (RHD) One of the chosen few.
did you replace any fluid? is the cap the right one and was it fitted properly?
1 - 10 of 10 Posts
