I just bought a 2008 GL450. I basically want to put the wheels and tires from a gl550 on my truck. Will they fit? Also where is the tire pressure monitor? Can it be switched between wheels?
2007 GL450
i have an 07 gl450..replaced my oem 18 rims and tires with oem 20's...the tpms is at the valve stem itself and can be removed and transferred..i had firestone do it and paid 120$ for the service and balancing...good luck
'77 450sl, 87 300D Turbo
if i were you, i'd go 22"
22s with 305/40/22. the tires are way cheaper. you can get Falken ziex with 50k mi warranty. 305/40s for anywhere between $140-170. you'll end up spending less and they look awesome. very wide and sporty. downside is the overall diameter is a few mm taller. so your speedo will be slightly off by a couple mph. but i think its worth the trade off. Looks better and they're cheaper. 22s with et50 offset.
GL450
So pretty. Love your wheels. Could you tell me your wheel and tire sizes please.
Looks like you have the twin to my wifes GL. Do you have more pictures from different angles? I was looking at adding those same wheels, but in a 20" size so allow her more "curb hopping" ability. :rolleyes:
Also, are they the gunmetal version or silver?
Thanks!
