1 - 20 of 142 Posts
1988 190E 2.3
DIY W201 Transmission Modulator Removal, Replace, Trobleshooting & Common Problems
Check out the links at the bottom of the DIY they have loads of information and troubleshooting guides for the 722.3 and 722.4 transmissions
I should not be credited for all the information in this post it is just compiled from hours of searching and compiling information from many sources and putting it all together in one place to help assist those with this problem.
Recently I have seen many questions pertaining to the Modulator and shifting problems. I put together this DIY to help assist with the common problems and effects of a bad modulator valve or vacuum leak and how to change and adjust the modulator on the 190E.
Diesel Owners this is a good link referencing the vacuum system and transmission on the 190D. This references how to adujust the system to get the best out of the diesel vacuum system and transmission modulator. Mercedes-Benz Transmission, Steve Brotherton, ImportCar, February 2002
Below are common questions and this DIY will cover them.
Common Questions
My Transmission slips/flares on 2nd to 3rd upshift Most likely the K1 piston spring problem that is common in these trannys read here k1-spring-kit-install.html
My Trans Shifts to hard? Most likely a vacuum leak or modulator adjustment
White/grey smoke coming from exhaust after adding trans fluid?The only way tranny fluid can get from the tranny to the motor is threw the modulator vale vacumm line.
My Trans feels like it slips for a second and then catches after stopping at a stop sign? Or my transmission is slow to engage?Most commonly a low transmission fluid level. Caused by a leak in the tranny or bad modulator diaphram allowing fluid to get sucked to motor.
My trans has soft or slow shifts? Soft Shift can becaused by the modulator being turned to low or a broken or worn modulator pin.
Before you begin with replacement of a Modulator Valve you should always check for vacuum leaks. Vacuum leaks are the most common reason for modulator problems. Vacuum leaks are common on older vehicles due to age and cracking. Vacuum leaks can cause various problems such as tansmission shifting hard and power locks not working correctly on the 190E or a bad Vacuum pump or leaks on the 190D can make the modulator function incorrectly.
The valve going bad can cause different problems. One being hard shifts. The other common problem is the diaphram rupturing in the modulator, causing it to suck transmission fluid from the transmission in to the motor this can cause white/grey smoke from the exhaust and transmission fluid loss. If fluid loss has happened then you may get a slow reaction time when the vehicle is moved to drive or reverse from the park position or you may have it feel like it slips and then catches when you come to a stop sign and take off.
Knowing Your Vehicle Transmission Number and Where to Find it
To get parts for your Mercedes 190 series vehicle you will probably need your Transmission Numer. It can be found on the side of the transmission above the pan see picture (courtesy of Member Samoila Stefan)
or you can decode your VIN here to get your transmission number.Mercedes-Benz Club Russia | Mercedes-Benz / VIN This is only good if you still have the original transmission.
Most commonly the first 10 digits of the number are the part number, the next 6 are the transmission number, and the last 6 are the serial number
(123 270 77 01 722 400 02 218853) Sometimes you may need this serial number because of changes made to that model of tranny.
Different Modulators For Different Models
Green 722.400,722.408 -722.403 722.410 Red 722.409,722.413,722.414
Recomended Transmission Pressure Per Transmission Model
MODEL________MODULATOR COLOR______PRESSURE
722.400 .....................Green..................46 psi (3.2bar)
722.403 .....................Green..................44 psi (3.0bar)
722.408 .....................Green..................57 psi (3.9bar)
722.409 .....................Red.....................48 psi (3.3bar)
722.410......................Green..................51 psi (3.5bar)
722.413 .....................Red.....................47 psi (3.2bar)
722.414 .....................Brown..................41 psi (2.8bar)
722.416 .....................Black...................44 psi (3.0bar)
722.418 .....................Red.....................47 psi(3.2bar)To serial #813648
722.418 .....................Black ..................47 psi(3.2bar)From serial#813649
Removal, Replacement And Adjustment of Transmission Modulator Valve
You need to do this to properly check the internal hydraulic pressure of the transmission after installing a new modulator.
Overview of What to do:
You are going to connect a psi gauge to a test port on your transmission's underside near your vacuum modulator.
Then, turn the car on and make some adjustments, and then remove the gauge and you're done.
You need to set the pressure correctly. There's a right answer - it's not a rule of thumb or by feel measurement.
Each transmission is different and You need the factory presure for your transmission.
Materials required:
- 12mm socket and 1/4"Rachet
-you can purchase a transmission pressure gauge set it works better to me just thread it in.
You can get one hereTransmission Pressure Gauge ATD5550
or hereATD5500
for under $35
OR you can make one this way
1 banjo bolt scrounged off of an ALDA on a yard car. The ALDA is the square unit on top of the injection pump on a turbo model. There is a banjo fitting leading into the ALDA from some clear tubing. Thats the one you want. Take the hollow bolt, two washers and banjo fitting.
- a few feet of 3/16" ID vinyl tubing rated for 60 psi or more.
- a 0-100 psi gauge.
-teflon tape for NPT fitting
-ramps for front wheels. Jackstands can work too.
-chocks for rear wheels
-TDM (Tecnical Data Manual) pressure settings for your transmission.
Gauge assembly:
-Make sure your homemade guage or the one you purchased is clean. Transmission fluid is going to go into this fitting, and then get sucked back into the transmission. You want this thing clean!
-attach your gauge to the hose fitting using some teflon tape.
- push the the ends of the vinyl hose onto the hose fittings on the gauge and the banjo bolt.
-make sure everything looks nice and tight. This stuff will be under 50-80 psi.
-wrap a plastic bag around the banjo bolt (keep it clean!) end of your gauge assembly and bring it to the car
Removal of Modulator
make sure you have the right fluid level in your transmission.
- put front wheels on ramps. Jackstands can also work, but get them up high!
-put e-brake on and chock the rear wheels. Safety first...
-turn car off and put in P.
-Remove the exhaust bracket form the rear of the transmission. You may also need to remove seporate the exhaust to get the transmission to lower enough to have good acces to the modulator
- Support transmission with a jack and Remove transmission crossmember by unbolting the two bolts on either side of the member and the transmission mount bolt. You may also need to unbolt the driveline carrier
-Lower transmission
Using a 1/4" allen socket with a long extension and a swivel ratchet remove the retaining bolts from the modulator.
-Remove replace modulator
If you are just adjusting the modulator you can leave the exhaust and transmount in tact but it will be very tight to work on.
It is also a good Idea to replace the modulator Pin which is located behind the modulator after removal these are know to break.
Setting the Modulator:
-make sure you have that pressure setting from the TDM handy
- a little below and to the rear of the modulator is a 12mm bolt. This is your test port. Unscrew the bolt and put it to the side somewhere...you guessed it..Clean!.
-screw in your banjo bolt or purchased guage. Point the hose up and to the rear of the car. BE VERY CAREFUL to seat the bolt correctly. Check again. If you dont, fluid will spew everywhere when you do the test.
-snug it down, but do not overtighten.
-look at picture this is how it looks, but you wont have red fluid in the line yet.
-check everything again, and crawl out from underneath the car.
-plug the vacuum line that dives down to the transmission from the engine compartment.
-start the car. Quickly look down and check for leaks.
-Fluid will be running down the tube, but wont make it to the gauge. A pressure reading will be registering on the gauge
-what you need to do next is make the adjustment. This is done on the modulator itself. There is a little black plastic cap that hides a t handle. To make the adjustment youll need to pull the cap off, pop the T handle out a little bit and screw IN(right) to RAISE pressure, and screw OUT(left) to LOWER pressure. Adjustment is a little bit at a time.
-the adjustment doesn't take long if you do it with the car running.
-once the correct reading is achieved, let the car idle for a bit and make sure the reading is nice and stable after the transmission is at operating temperature.
-turn the car off.
- take off the banjo bolt or purchased guage, reinstall the 12mm plug bolt. re install the modulator rubber cap. reconnect the vacuum line.
- remove chocks, take car off ramps. test drive
Be sure to view these links they will help you out alot with the 722.3 and 722.4 transmissions.
http://transtec.com/tech_insert/94642.pdf
ATSG repair manual automatic transmission 722.3, 722.4
http://www.autotransonline.ro/cataloage/EUROPENE/MERCEDES/722-300-400.pdf
1992 2.3 190E
Hattenator
Nice job so far. You found a number of the articles I found as well.
One paragraph has you disconnecting the exhaust from the motor. Being picky, the trans is lowered then start the car, the exhaust will needed to be hooked back up and one would assume if that is required, then you will have to raise the trans again, then remove to make an adjustment, lower/raise/lower/raise per test and again to remover the gage once done.
Two detailed articles said to disconnect the bracket from the trans to the exhaust pipe , not the exhaust from the motor. Typo maybe?
One is I hope the exhaust can remain in tact and have enough play to come down a bit. I am concerned on my 92 2.3 the drive shaft can remain attached as well. There is a bracket that might allow a 1" drop. We will see as I will be doing mine soon.
The Banjo Bolt Thread is still a problem for me. I don't want to go looking around in Wrecking Yards looking for 190D in tact. Still looking.
Also, and I will find it. The Data sheets are hard to read, I found a list retyped somewhere.
Link to any of the good detailed sites would be a plus. More the merrier.
Dan
1992 2.3 190E
I have only started reading on this site, but there's lots of info here on transmissions. Mine problem is a lazy shift at 50% throttle, it may not even be the Modulator, but I will be doing the modulator before going here, for more adventurous DIY's.
I found Trans Test Kits, but they come with a number of different threaded fittings, so still looking for the test port thread. I may have to pull my plug first and measure it myself.
http://********/articles/transmission/k1/
Dan
1988 190E 2.3
As the DIY states you can leave your drive shaft in place but you may need to unbolt the drive line carrier to give it some clearance.
It is possible that you can do this with the exhuast just unbolted from the transmission but I am not sure it will give you the maximum amount of room possible if you are changing the modulator.
If I was just going to adjust the modulator I would try to take the least possible apart just to get a little more room for the adjustment.
Lazy shifts can be caused by the modulator being turned down to far as to where hard shifts are caused by low or no vacuum or modulator turned up to high.
Instead of looking around for a banjo bolt it also states in the DIY you can buy a transmission pressure tester. you can get one of these for around $45.
I will make sure to add the lazy shifting to the DIY
THIS POST WAS EDITED TO ADD THE FOLLOWING
1992 2.3 190E
Agreed, undo as little as possible to do the job is my motto, but sometimes it is just better to bite the bullet and get some stuff out of the way, I usually make it tougher than it needs to be. Unbolting the exhaust if needed is not a big deal, just more work.
You already gave my the idea for Googling, I went looking at Trans Test Kits. They come with an assortment of fittings, but I can't find anything yet that says it will work with our trans.
I am quite concerned I may be doing the K1 valve, problem description fits me to a tee. Perfect shifts all gears at low or high throttle positions, but a lazy 2nd to 3rd around 50%. Modulator first and we will see.
Dan
1988 190E 2.3
I found all of the modulator pressures for transmissions I only added them to the post, there may be a couple that are for a different models but most are for the 190 series
'01 SLK230,'93 190E 2.3, 1971 LS5 Corvette Convertible
Just an added note for replacing the Vacuum Modulator.
When I replaced the VM on my '93 2.3, the first time around I removed the trans. cross member, but the transmission wouldn't lower enough to gain access to the VM bolts.
So I posted on this site, and thanks to fellow member MTI, he advised me to remove the exhaust/muffler hangers and brackets so the transmission would drop down far enough to get to the Vacuum Modulator. Needless to day, it worked!
Also, if anyone is doing this procedure, this would be the time to replace those worn out shifter linkage bushings. Cheap parts and it make a huge difference...tight and no more rattle.
1988 190E 2.3
I believe in the DIY I have the exhaust listed to be removed for changing the modulator. Thanks for the tip on the bushings they are a common problem and that would be a good time to change them
Just as a Note I will be adding more troubleshooting tips to the main post some will not be modulator related but they will help everyone out on diagnosing there transmission problem.
1992 2.3 190E
I believe it's the exhaust hangers at the trans, not the exhaust itself off the exhaust manifold, right?
Good find on the pressure list.
Dan
1988 190E 2.3
Discussion Starter #10 (Edited)
I need to take a picture of that and edit the post. You can drop the hanger or you can drop the hanger and drop the exhaust at the front.
Just so you know I will be updating a few things on the DIY be sure to check the links I add out they will have alot of info including trobleshooting for the 722.3 and 722.4 transmissions. they should answer just about any question any one has about thes transmissions.
1992 2.3 190E
Very detailed rebuild links, especially the last one. Shift complaints in just about any combination you can think of and the remedy. Except, the number one complaint is the hard shift 1st to 2nd with actually is not addressed other the All shifts being harsh it's vacuum and or modulator adjustment.
Still don't see the Thread of the test port :-( , but one thing I was wondering about to save time is one click on the Adjusting Pin is approx .4 bar which would help get in the game sooner.
Dan
1988 190E 2.3
Discussion Starter #12 (Edited)
just pop the test port bolt out and check the bolt threads and diameter any good hardware or automotive place that sells metric bolt should a thread pitch guage. then you will know and it shouldnt be too hard to get that bolt out.
Have you checked your vac lines yet going to the modulator. if you pull the line off a modulator and then drive it you get that hard shift from first to second you are talking about. I would check the line if you havent
1992 2.3 190E
I have calipers and a thread gauge but yes that works. Hard shift is not my problem, but yes I am aware of that test. My 1st to 2nd is gorgeous as is 3rd to 4th.
Keep up the good work.
Dan
1988 190E 2.3
Discussion Starter #14
is it a flair in the second to 3rd shift if so it will probably be the K1
1988 190E 2.3
Discussion Starter #17 (Edited)
Dan does this sound like yours
This link goes to a detailed pictured walkthrough of this proceedurehttp://www.benzworld.org/forums/w201-190e-d-class/1361737-diy-mercedes-722-3-722-4-722-5-transmission-k1-piston-spring-repair-kit-install.html
The K1 Kit Page
2/3 Upshift Flare Repair
This is a fix for transmission slip/flare on 2-3 upshift at partial load for 722.3,722.4 and 722.5 automatic transmission
If your automatic transmission shifts fine with the exception of a flare on the shift up from 2nd to 3rd, and you've exhausted all your adjustment options, then the K1 Accumulator Spring Kit might be the solution.
The spring kit (part number 126 270 44 77) will cost you less than $10, and is a drop in replacement for the K1 accumulator's spring/piston assembly in your transmission's valve body. While you're buying parts, you will also need several quarts of transmission fluid and a new gasket for the pan. You might as well change the filter while you are in there too.
Before you begin. Get some old newspapers/cardboard underneath the transmission. Fluid will be constantly dripping while the transmission pan is off.
Begin by draining the transmission fluid. On my W126, I also had to remove the front crossmenber (by undoing 3 bolts on either side) to get the necessary clearance to unscrew the K1 accumulator cover. NOTE: MB recommends replacing these bolts. You may want to support the crossmember with a small jack to avoid it clattering to the ground.
Once the fluid's drained, unbolt and remove the transmission pan. Again, you might want to use a small jack to support it. Also, bear in mind there will probably still be fluid in the pan.
Locate the front of the valve body. You will be unscrewing 4 screws and removing a rectangular cover.
NOTE: The four screws for the cover are very tight. I ended up using a 1/4 inch driver with a flat-headed socket to unscrew them.
This was especially useful for the top screws, since the curve of the torque converter housing made it difficult to turn a screwdriver.
Pull out the spring/piston assembly from the valvebody. It'll look something like this.
Go ahead and pull the spring assembly out from the tube. You'll notice that there is also a small spring left at the bottom of the tube. Remove that too.
Put the old springs aside and open up your new parts. First of all, drop the new small spring into your old tube.
Next, loosely assemble the rest of the pieces from the kit (2 springs, 2 plastic rods) like so. NOTE: It may not be obvious from the picture, but the smaller spring goes on the white rod, and they are then inserted into one end of the big spring.
Now the fun part. You're going to have to squash that loose assembly of springs and plastic rods together. Carefully. The white rod will fit into the black, but it does take a fair bit of pressure to do this. Once the 'head' of the white rod is in all the way, the entire assembly will hold itself together (just like the old one does). Just be careful and take your time. Remember, your dealing with springs under pressure, and parts can go flying if you're not careful (don't ask me how I know).
Before putting everything together, make sure everything is nice and clean. When you're ready, drop your new spring assembly into the tube like so.
Now put the entire assembly back into the valve body, and screw the cover back on, nice and tight.
From this point on you are effectively following the same procedure as a transmission fluid/filter change. If you are also replacing your transmission filter, now's a good time to do so. Put your new seal on the transmission pan, and bolt it back up (don't overtighten it either). If applicable, bolt your front crossmember back on, and fill up the transmission, being careful not to overfill it. NOTE: The transmission dipstick under-reads when the transmission is cold.
Before going for a test drive, start the car up, and with the brake on, run the gear selector up and down the gate, pausing a few seconds at each position, so the gear engages/disengages, and the fresh transmission fluid gets a chance to circulate properly.
Hopefully, you should notice an improvement in the 2-3 flare. You may find that you have to make some adjustments, since it's possible that the transmission was previously adjustated to try and compensate for the flare.
1985 w201 Euro 2.3-16vlv / 1992 w201 2.6 Sportline Manual
Don't thank me bro. Thank yourself for posting helpful information for other users.
Woah this is exactly why I logged on today. Too weird it was the first post and I didn't have to search for info. Anyway thanks a bunch for posting all this I'll take it as a sign I need to swap my modulator asap
thanks again
1988 190E 2.3
Discussion Starter #20
190ED
you are very welcomed and I am glad I could help and I hope it helps alot of people with tranny problems. what problems were you having with your 190
1 - 20 of 142 Posts
