101 - 120 of 130 Posts
Outstanding Contributor
2002 ML320, 2003 A160, 2002 ML500, 2018 GLS350d
2002 ML320, 2013 GL450
Front shock absorber DIY
Attached is a youtube video on changing the front shock absorber.
Reactions: Jetpilot718
14’ ML63 AMG
W163 Crash Test Driver
2008 ML350 (Me!), 2010 GLK350 (Wife), 2003 ML-350 (Deceased)
02 ML320 06 ML500
R&I EGR Tube & Valve
With code P0400, 9 times out of ten it refers to a clogged EGR tube. To check for a clogged tube, proceed as follows:
1. remove the Air Intake hose assemble.
2. remove hose b at vacuum unit.
3. remove T30 Torx bolt at Transducer Y31/1.
4. remove bolt below (cannot be seen in photo) and push Transducer aside. This will give you more swing room for wrenches.
5. counter hold lower nut with thin 22mm stubby wrench, while loosening large 24mm Union Nut (89/3).
6. then remove the 2 Torx bolts at the Intake Manifold.
7. then pull out the EGR tube. This is the most difficult part as the tube has many bends and will need to be twisted in different directions in order to remove it.
8. things will be easier if only the bolts to the Coolant Expansion Tank at the firewall are removed and while holding the Expansion Tank maneuver the tube out of the hole.
9. if the tube is clogged you can either clean it manually or replace it new. If it isn't clogged replace the EGR Valve.
Red 1987 560SL, Grey 2010 ML350 (gas), Grey 2010 E350
ML320 Fuse and Relay Diagram
Here is the Fuse and Relay Diagram from my 2002 ML320. Thought I would post it in the DIY Sticky in case someone needed it for a desktop reference.
2000 Mercedes Benz ML320
DIY - Testing the Stop Lamp Switch (S9): ML320 2000
DIY - Testing the Stop Light Switch (S9) (aka Brake Light Switch)
Car Model 163.154 /157 /172 /174 /175
The Stop Light Switch (S9) can be the cause of problems in a number of systems – ABS, ESP, ETS, to name a few.
Before installing a replacement switch, one can do a testing of the switch, to make sure it is faulty.
The Stop Lamp Switch (S9) is in fact an assembly of two switches: one SPDT – single pole double throw - and one SPST NC – single pole single throw normally closed. The SPDT is known as Switch A, or the Release Switch, while SPST NC is known as Switch B, or the Brake Light switch.
Testing:
a. The switch can be tested without a full removal, with a Scanner, if the scanner can collect BAS live data.
Collecting live data of the Switch in the BAS system will show the two switches state changes from Closed to Open, when activating/deactivating the brake pedal during the data collection. See bellow an illustration of the BAS live data collected with Auto Enginuity Scanner (laptop software and USB hardware connector):
b. The switch can be tested with a Digital Volt Ohm Meter (DVOM) after removing it, by testing continuity at the contact tabs, while moving the switch pin from Normal/Relaxed to Pushed In/Compressed. The Open/Closed States of the Switch should follow the illustrations bellow, for correct functioning.
A DVOM test need be complemented by a Live Data Test, because the timing of the switch state change is important. The state change is checked against the pedal travel – an excessive pedal travel (more than 3.5mm) before switch state change may be considered as a defective switch.
mercbentz
(Cont)DIY - Testing the Stop Light Switch (S9) (aka Brake Light Switch)
mercbentz
See an illustration of the Stop Light Switch functioning by ways of Live Data bellow:
Brake Pedal Position/Travel is reflected by the Diaphragm position/travel
My caris vibrating the speedo,rev,petrol,temp sticks when i start the car and when i switch off the car what might be the problem and i tried diagnosing the car but still no code detected.
W163 and General Mercedes Host
2002 ML320 - no GPS or phone but 6-CD changer in rear right installed - I have a Droid mobile now.
