heres a how 2 installed aux jack into g class i did this on mine and its an 2003 (i know people sell kits but here the parts numbers
This bulletin has been created and maintained in accordance with MBUSA-SLP 5.1, Document and Data Control, and
MBUSA-SLP 16.1, Control of Quality Records.
© 2002 Mercedes-Benz USA, LLC All rights reserved. Reproduction or translation in whole
Mercedes-Benz Canada, Inc. or in part is not permitted without authorization from the
Technical Information publisher. Printed in the USA.
Mercedes-Benz Luxury Cars: Explore, Build & Compare Sedans, SUVs, Coupes, Wagons 1-800-FOR-MERCedes
Install
Date: September 2002
Order No.: T-I-82.85/191
Supersedes:
Group: 82
SUBJECT: MODEL 463.249
MODEL YEAR 2002
AUXILIARY INPUT HARNESS INSTALLATION (G-CLASS WITH COMAND)
We are interested in your comments and/or suggestions regarding these installation
instructions—please e-mail them to:
[email protected]
Note: Installation of the auxiliary input harness is not covered under warranty; it is a customer pay
option.
1. Remove the glove compartment.
• Refer to WIS: AR68.10-P-1400GM,
“Remove/install glove compartment”
2. Measure and mark the glove compartment
left side at the point where 80-mm (A, Figure
1) from the back edge and 30-mm (B, Figure
1) from the bottom edge meet.
3. Make an 18.8-mm hole at the measured
mark (C, Figure 1).
Figure 1 P82.85-9758-01
2 T-I-82.85/191 September 2002
4. Remove the quick-release connector lock (A,
Figure 2) from the auxiliary input harness
connector (B, Figure 2).
Figure 2 P82.85-9759-01
5. Insert the auxiliary input connector into the
drilled hole from outside the glove
compartment (Figure 3).
Note: Be sure the edge of the glove
compartment hole inserts into the groove in
the connector (C, Figure 2).
6. From inside the glove compartment, lock the
connector in place by inserting the quickrelease
connector lock into the connector
face.
Note: Be sure the spines (D, Figure 2) of the
quick-release lock inserts into the
corresponding notches (E, Figure 2) in the
connector.
Figure 3 P82.85-9760-01
7. Clip off the terminals from the individual wires
of the auxiliary input harness (Figure 4).
Figure 4 P82.85-9761-01
T-I-82.85/191 September 2002 3
8. Install the new terminals (part number: A 008
545 55 26) to the auxiliary input harness
wires using the appropriate tools from the
wiring harness repair kit (part number 220
589 01 99 00) (Figure 5).
9. Remove the COMAND unit.
• Refer to WIS: AR82.85-P-7472GM,
“Removing and installing operating and
display system with control module”
Figure 5 P82.85-9762-01
10. Position the glove compartment near its point
of installation and feed the auxiliary input
harness end through the glove compartment
opening to the space vacated by the
COMAND unit.
11. Reinstall the glove compartment.
12. Locate the disconnected C-2 plug in the
space vacated by the COMAND unit (A,
Figure 6).
13. Remove the pin connector from the C-2 plug
(B, Figure 6 and Figure 7).
Figure 6 P82.85-9763-01
14. Connect the new terminals on the wires of
the auxiliary input harness into the pin
connector (A, Figure 7).
a) Thin-gauge black wire into pin-13 (A,
Figure 8)
b) Thick-gauge black wire into pin-14 (B,
Figure 8)
c) Yellow wire into pin-04 (C, Figure 8)
d) Brown wire into pin-05 (D, Figure 8)
Figure 7 P82.85-9764-01
4 T-I-82.85/191 September 2002
15. Reinsert the pin connector into the C-2 plug,
making sure the arrow on the pin connector
points toward the C-2 plug (B, Figure 7).
16. Reinstall the COMAND unit.
17. See page 225 of the COMAND Operator’s
Manual for instruction on switching on the
auxiliary audio source.
Figure 8 P82.85-9765-01
Parts Information
Qty. Part Name Part Number/Exchange
1 Auxiliary input harness A 203 540 61 07
4 Terminals A 008 545 55 26
the dealer will install this if u give them the wis number at the top
will add picks later just did this really fast for another member who needs the info
