Guys: I have blown my dash speaker and would like to unplug it, can it be done by the lamen or do I have to take it in to my local autosound guy?
Thanks DG
It is very easy.
You need to slide a flat head screw driver into the bottom slit on your speaker grill and unlatch the two latches holding the grill in place. Pull the grill off. You will need to unscrew two torgue screws. Torque screw drivers can be purchased cheaply at any auto store or big box store. Then pull the speaker out and disconnect the wire.
