Okay got the shifter repaired yesterday. As always, when you are doing something for the first time, it takes twice as long. This is an involved procedure, not technically, but tight quarters for access, being very careful wilth the trim pieces, the car has to be jacked up for access to the transmission shift rod, drilling the rivets on the shifter. Putting it all back together was a snap after the replacement lever was installed. I used the MB repair PDF's which is imperative, as the sequence of removing the various compoents must be adhered to, so that you don't have to go back and repeat the removal. MB suggests using ball hex wrenches to remove the bolts that secure the shifter to the body. I didn't have any so I had to loosen the console, first by removing the rear storage compartment, then raising the console and pushing it to one side so that I could use a regular hex wrench, you'll need torx wrenches sizes T-10 to a T-40, the hex is 5mm and your regular assortment sockets with a swivel connector. The job is 5 on a scale of 1 to 10 and Star is not required.The video on YouTube left off a couple keys points and I'll go over those. I'm not sure how to attach the MB PDF repair manual instructions, I'm only able to print them, I may have to scan and attach as GIF. If anyone can help me this it would be appreciated.
The first step is to remove the side paneling, Use the plastic pry bars designed for this purpose Start from the center top and work your way toward the ends, As you can see these are metal clips, not the typical plastic ones which have a tendency to break. Once they are removed there are three torx screws on each side along the top. They are about an inch and a half long. Next remove the shifter lever cover. place a wedge under the leather , pry up and push up over the top of the knob, exposing a black plastic locking ring, turn it 90 degrees counterclockwise and pull off the knob.
