2004 CLK 500 Previously: 2001 CLK 430
So next on the to do list is my side marker bulb socket.
I went to replace the bulb when I got my clear side markers a few years ago but never got around to it until now.
Here is the ebay link I found the socket.
NEW OEM Genuine MERCEDES BENZ Side Marker Light Bulb Holder 1pcs A0005400966 | eBay
I first tried to do most of this outside when it is kinda dark since that is when I have time buuuuuuut I found it was easier just to cut about 2 inches of the wire off and bring it inside.
Here is the new part
Here is what you get
New bulbs from Canadian Tire for about $6
The tools you need plus some electrical tape
Here it is with not working :(
Corroded connector
I snipped it about 2 inches from the socket
Slide the green plug on and crimp the new connector on
Right in the middle is a little tab....
That has to click into this little slot
To be continued.....
Discussion Starter #2
Once both are clicked in, put your bulb in, if those connectors didn't click the bulb won't stay in
Twist your wires together (BTW they are 16g) and tape them up.
Reinstall to the side marker lens and pop it back in place.
Ahhh sweet victory
On the PITA scale this is not bad, more for me because i like to do things twice before realizing I'm doing it the hard way.
Yes I PM'd Marsden to add this to our awesome repair thread we have.
2005 CLK320, 2009 E350
Only thing I would change would be to solder the wires instead of just twisting them together and using heat shrink tube... that's asking for it to fail again and it will.
-Nigel
