1 - 8 of 8 Posts
1997 S500V
HI,
Summer in TX is approaching so I did some AC work for a friend on an 97 Acura which has a small leak but usually needs a can of R134a.
I also decided to check the S500...
This time around, I noticed and rented a real nice master cool R134a 2-way manifold gauge set from AutoZone for FREE ($99 deposit/return). The kit has EZ lock fittings and a nice refrigerant can valve. They also have a 2CFM rotary vane vacuum punp for rent which I didn't need.
I picked up a case (12-12oz. cans) of Johnsens R134a from SAM's for $36. Come's out to $3.04/can. Pep Boys sells it for $9-14/can...
So, here's some pix with hi side (red), low side (blue), and can (yellow) hookups. Based on ambient temps, 85F and looking at the temp chart, I was low about 1.5-12oz cans. I ended up using a little over one can and my AC improved quite noticably for ~$5 :) The AC has never been serviced or checked in over 10yrs...:confused:
HI,
Hey Moss500,
Thanks a bunch for posting these pictures!
I'm going to try recharging my AC with your guidance, tomorrow. I just replaced the AC control module in the dash and the blower regulator under the hood. Everything is now working except blowing hot air.
If the R-134A charge works you just helped me save $500 bucks, minimum.
Awesome!
HI,
Hi MOSS500 and Others...
I tried to charge my A/C. I bought a can of R134A with integrated pressure guage and plugged it into the low pressure nozzle after running the car with AC on High for 3-4 minutes. I did not plug in anything to the high pressure (larger) nozzle in the front of the car by the radiator.
When I pressed the button on the R134A can.. the pressure guage simply dropped slowly from about 35lbs to Zero.
Any suggestions?
Thanks All - JimK in Seattle
2006 S500 AMG Wifes Rig Hillbilly Girl 02 ML320
If your system was empty it means that you still need more 134!! 1 can ain't gonna make it!!
Smokie
SL55, 300SE, GL450, Daytona 955i
Smokie
Yep...
the user manual of your car will have the specs for your car's capacity.
1997 S500V
Discussion Starter · #7 ·
If your topping off, something doesn't seem right. Your low side should be anywhere from 25-40psi depending on ambient temps. Sounds like your AC system is completely empty as others have speculated. If thats the case, you need to pull and hold a vacuum of 25" or better for an hour otherwise you have unacceptable leaks that need to be addressed....
Thank you for the information OP
I just emptied out a 22 oz. giant size "arctic freeze" of 134a+ can into a 1993 W140 500sel this morning and the a/c is once again "blowing sharpy cold"!
Many thanks to your very helpful diy.
1 - 8 of 8 Posts
