I have had a small leak on the left side for years, it would only leak one drop during storage of 3 months.
When I would start the car everything was OK but as it warmed up the oil would burn off on the heat shield. The last time I started it it got much worse, the time has come to change the gasket. In this pic you can see the oil fill tube has evidence of seepage, we will fix that too.
Lifting off the engine cover, right side first.
Then continue to lift the front of the engine cover on the left side. The clips at the rear will turn loose as you lift the cover.
The cover is off and you can see more evidence of seepage around the oil fill tube extension.
This is the left side valve cover that will be removed.
Good idea to protect your fender and paint, I use packing blankets for my comfort.
First step mark your coil wires and coils, cut the ty wrap to free the loom. Swing the coil wires back by the firewall, out of the way.
Remove the plastic clip between the fuel line and vacuum line. It will not be necessary to remove either the fuel line or vacuum line.
Once the coil is free from the valve cover, you can use a 17mm open end wrench to pull the spark plug boots off. Be careful you can break a plug, pry the boot off gently. Member Oh Lord has a boot removal tool (for sale) that I am sure works better than a common wrench. That said, if you have changed plugs on an air cooled 911 these boots are first cousins. pita
All the coils removed. Starting to break loose the fasteners.
We are about to remove the valve cover, before we do I vacuum the area around the cover to remove any dirt and debris. You don't want any dirt to get in your engine.
Disconnect the large crankcase vent hose.
disconnect the small crankcase vent hose, it is hard to see, just under the red drop light. Ready to lift off the cover.
Cover off, and every thing looks good. The gasket stuck to the head so the leak is between the gasket and cover.
This is the rocker set for Cyl #8 under the exhaust rocker you can see the place (white spot) where the oil drops burn off on the heat shield.
If you like how clean the valve train is, All I can say is, Mobil 1 0W40 this engine is on its 3rd oil change (oil change @ 10K mi) over 10 years. I also use only BP ultimate (Clear 93) and every mile is documented.
Here is the valve cover back after a visit to the spa, all clean and de-greased.
First item to reseal is the oil fill extension. In the next few pics it will appear that I use a liberal amount of Blue RTV that is not the case. For some reason the blue looks larger in the pics. I always try to use a thin film of blue RTV.
Bead on both parts.
Install filer extension, note no RTV coming out.
Small continuous bead of Blue RTV sealant in the gasket channel.
Bed the gasket in the RTV and wipe any excess off.
Again lay a small continuous bead around the gasket surface. Then smooth it to a thin film no higher than the ribs on the gasket. Ready to reinstall, make sure the old gasket is removed and the sealing surface of the head is clean and oil free.
When installing the cover try to do it in one shot, and avoid sliding it around on the head too much. Start all your fasteners by hand first. Then tighten them in a circular pattern, starting at the center and go around in an ever widening circle. Torque the fasteners in three stages 40-60 then one hour later 72 inch pounds.
Here I am installing a ty wrap to act as a hose clamp on the crankcase hose. They get a little stretched when you remove them.
The two breather hoses should be replaced when doing this job, no need to zip tie some junk parts back on when new ones can be had for around $20.
Also, for the love of god, RTV sealer is not needed anywhere on this engine that already has a gasket. If you cant repair the leak by using factory repair methods and parts then you should take it to a professional. If you just put a gasket and follow factory repair instructions it will not leak
Umm, I think knowbenz is correct. The breather hoses, if original, are very brittle (mine were cracked and broke off). Also, when I told my friend, a long time Mechanic at the San Jose Mercedes dealership about the RTV, he said not one mechanic at his dealership uses anything other than the gasket. I would imagine everybody has their own recipe, though.
This DIY from Yacht Master is fabulous and the pictures alone make it well worth anyone's time to read before starting.
I also think that RTV isnt needed. The only time I'll ever use a sealant is to hold the gasket to the valve cover if it is held loosely. If the sealing surfaces are in good shape, there's no reason to use RTV on there. You also risk getting chunks of it in the sump and clogging up the oil pump pickup. I've seen motors burn up crank bearings because of this. Also, you should see what happens when you introduce RTV to gasoline.
How'd you get the driver's side cover back on w/ the hoses in the way? I removed mine tonight and had a tough time. I was banging up against the hoses, the camshaft gear, and other under-hood equipment before I finally got it out of the car. I don't see how it can be put on the car in "one shot" as I think you called it.
It is a bit of a pain, but I was able to pry up on the hoses and such with the backs of my hands to get the cover on without touching the cam. Do a dry run before trying it with the gasket.
i hope you don't work at a restaurant. are those food dishes next to the valve cover?
i don't think it matters if you use rtv or not. personally i would use it. if it came from factory without rtv and it eventually leaked, then it won't leak now with rtv.
Great instructions. I know it has been awhile since the OP posted this, but thanks. If I ever have to this to the 3.2L engine, I will use this as a template.
I purchased this car from a one-owner who had stored it in a heated storage building for years. I had it inspected by Mercedes, and completed several maintenance repairs.
One of the things I have noticed about the car is that it takes longer than I would expect to crank. I have to turn the...
Hi guys ! My 01 E430 4matic has 13 years old battery.. winter is coming and according to the news we is going to have rough winter ...
Should I replace the battery or just get small jump boost and keep old battery ??? Just in case.
Last winter we had like -10 F ..and the engine was turning...
Can anyone recommend a trusted supplier for the 2002 E320 headlight wiring harness? In many threads, people got the harness from eBay or Amazon 3rd party sellers. Even in the DIY by gurunutkins, the harness he linked to (in a different post) now shows a photo of some ugly watch.
My headlight...
This is a more appropriately titled thread than my first thread about this. I have more work to do from that thread, so I'm not abandoning all the good info there. I just want the proper thread title.
My 2002 E320 4Matic wagon has had a rough idle for over a year, but it always drove fine...
My daughter has a 97 E320 sedan w/130K miles bought used at 80 k miles that just went into limp mode. I pulled codes P0715, P0720 and Pending code P1560 or P1530. Tried to reset using my cheap scanner, but no fix. Here is the history:
Daughter in car wreck two years ago, hit hard from the right...
