Here are some easy steps to remove your mirror housing. To add chrome, change the LED signal, and moddify your light pipe if you want...This seems like and easy job and it is...
Jake
1. grind a small # 1 phillips screw driver to develop a small flat at the nose
2. cut a small section of .25 - .375 tube into a two (2") inch section
3. bend mirror housing back toward the rear of the car, insert the small section of tube onto the nipples / tabs located in the mirror frame and mirror hinge
4. insert a long flat blade screw driver from the front end of teh vehicle into the mirror housing. locate a molded in key way to a small .75 inch vertical metal tab. move that tab outboard from the vehicle and gently begin to slide mirror housing back. to not bend the spring clip - that is the retainer for the mirror housing unit.
5. remove the old, stock, etc. LED case with the ground phillips screw driver - or do what ever it is you have to do...
6. make sure the clip will retain the housing, it should be self loading and ready.
7. reinstall!
Jake
7. reinstall!
