DIY Front Wheel Alignment - E500 W211
30096 Views 9 Replies 8 Participants Last post by  dunnman99
After several bad alignment jobs, I decided to do it myself:
Check out my blog:
Mercedes DIY Alignment
Also, here is my blog on DIY Mercedes Ball Joint Change:
http://diyw211balljointchange.blogspot.com/
Thanks!
1 - 10 of 10 Posts
that's a nice write-up. Sometimes those alignment guys doesn't really know what they are doing. I brought my car in Fletcher Jones Newport Beach for alignment and to my surprise it was done in less that 15mins and that includes test drive. Sometimes its frustrating and really better doing it yourself.
Did that fix you alignment problem? Did you test it on high speed?
Well, I only did it yesterday. And after a short test drive, all the pulling is gone, but to be honest, it just slightly still drifts to the right. I'm going check the air pressure and measure it again over the weekend, just to confirm it's perfectly at zero.
Discussion Starter · #4 · (Edited)
Mercedes DIY Wheel Alignment
Why?? I purchased one of those life time alignments from Firestone back in 2007. The first time, the alignment is perfect. Car was running straight, nice print out of specs, no problems. Then, I replaced my ball joints and lower control arm. I brought the car back to the local Firestone. 2 hours later, no print out, car was pulling to the right. Worst then when I first installed the lower control arm without an alignment. A week later, I brought my car to a second Firestone. The guy aligned it again, told me it was way off. Another 2 hours, he was done. He drove it around the block, told me it was still pulling, then proceeded to adjust my tie rods WITHOUT the machine. WTF!?!?!?!!? He told me his eyeballs were more accurate then the machine. I drove home, car was still pulling. I decided if I wanted this to be done right, I need to do it myself.
Of all my alignments, I don’t think they have ever adjusted the camber or caster, only toe.
This method, is a combination of all the different DIY articles I’ve seen on the web. I believe, is the least expensive, most accurate and easiest method out there. I spent less than $10.
Tools needed:
Straight wood Stick 8 feet long ($1.89)
Two 2x4 wood blocks (Already have)
Metallic Sharpie ($2.89 – packet of 2)
13 MM Open end and an adjustable wrench (Already have)
4 vinyl Floor Tiles ($.89 each)
Bearing Grease (Already have)
Jack (Already have)
1) Put the 8 foot stick in front of the tires and select a spot on the tire that has the best contact.
2) Jack up the car, and using a metallic Sharpie, draw a line around the tire while it is rotating. I used a drill vice to hold the Sharpie to make a perfect line.
3) Loosened the tie rod ends’ lock nuts
4) I have a long drive way, so I drove it back and forth twice, then rolled into my garage
5) Just before stopping, I placed homemade turn plates in front of the tires, proceeded to drive on to them. (Homemade turn plates –Bearing Grease sandwich using 12x12 vinyl non-adhesive floor tiles. I was able to turn the wheels with my hand. Be sure to leave the keys in the ignition to prevent the steering lock from engaging)
6) Make sure your steering wheel is straight
7) I placed a 8 foot 1x2 stick in BACK of the front tires. Using two 2x4 blocks, I placed the stick as high as I can without touching the car.
8) I made exact matching marks on both sides of the stick as the two sharp lines on the tires
9) Now, I moved the stick to the front of the front tires using the same blocks. Be sure to match one of the marks to the tire line. I chose to match the driver side tire because I have more space in my garage on that side. (you will only need to make one additional mark)
10) On the passenger side tire, you see the difference between the measurements of the marks and the lines on the tires (my car had a toe out condition, almost ½ inch).
11) If your car is out of alignment, you will see the difference between the two marks.
12) Your perfect alignment will be the mid-point between the two marks.
13) Proceed to adjust your tie rod ends – I recommend moving both rod ends in small increments until the tire lines match with the correct alignment marks on the stick. (Remember, you only need to adjust half that distance since the rear of the wheel will also move as you adjust the tie rod end)
14) Tighten your rod ends, turn your steering a few times, and re-measure front and back. Make sure the alignment is perfect.
15) Now you have perfect alignment.
I truly believe this toe alignment is more accurate than any machine can achieve.
Note: This method is usually better then string methods since the string method is not accurate if every one of your measurements are not perfectly squared with what you are measuring. With this technique, measurement errors are not introduced into the alignment process.
Note: Also, you can put a slight toe in (front of the wheels are slightly pointed in) on your alignment, which helps with high speed stability.
“Toe is always adjustable in production automobiles, even though caster angle and camber angle are often not adjustable. Maintenance of front end alignment, which used to involve all three adjustments, currently involves only setting the toe; in most cases, even for a car in which caster or camber are adjustable, only the toe will need adjustment.”
GL320 CDI - 2008, '04 Touareg V10 TDI, '85 Unimog U1700, '83 Mitsubishi 4WD turbodiesel PU
Excellent idea on the homemade turn plates (bearing-greased vinyl tiles). I've done toe in adjustments a lot of years and never thought of that one!:D:D
I also really helps to know your garage floor is dead level.
E500
Another good write up.... I have done alignments on my corvettes for years.
Amazing what you can do with an inclometer, tape measure and string.
06 E350 AWD
You my friend are a freakin genius...i knew that buying a luxury car would be costly to maintain however some of the prices the dealer (aka stealer in this site) are just plain daylight robbery. i have always worked on my hondas but my w211 is different and i am kind of hesitant to tear it apart....good job on the illustrations on both the ball joints and alignment........
95 E300, 91 300TE, 84 190D
What if onlt one side out of spec?
Old post I know. Doesn't this technique assume that both sides are out, and then so both sides are adjusted to realign?
Suppose one side is correct, and the other is out. Using this technique, wouldn't you end up adjusting the correct side to out of spec? We are adjusting both sides to make up for the uneven measurements, so aren't I bringing the out of spec side closer to spec, while adjusting the correct spec side to more out of spec??
Thanks for helping my small brain think this through.
I have a Mustang that I road race and have been aligning it with a framing square and tape measure for 23 years! It's easy as long as you aren't trying to adjust the caster. Scribing the tires like you did and checking the toe with a tape or stick is super accurate, if you don't want to use turn plates you need to back up the car and drive it foreward after every adjustment.
Dan
2003 E500, base model, non-4matic, 1965 Shelby GT350, 2011 Hyundai Tucson GLS, 1989 Honda RC31/GT647
I have a single question:
I have seen a part available for pre-tensioning the front steering prior to alignment. Is tensioning required? Front of the tires out or front in, tensioning?
Thank you
1 - 10 of 10 Posts
