89 Mercedes 300E, 91 Mercedes 300CE, 71 BMW turbo 2002, 73 BMW 2002tii, 85 BMW 635csi
Mine is jammed up, not pumping or buzzing with direct 12V . Replacement around $400............. nu-uh :nono: Not at least yet.
You can use kerosene or diesel fuel or something like Varsol. I had two short pieces of hose- sucked out of a 1L yogurt tub and discharge straight back in again.I just finished doing this, and when I applied voltage I did get a buzzing sound. But it wasn't as loud as Nutz'. If it wasn't turning, would I hear anything?
I didn't do a before test because I was worried about igniting gas still in there.
What is safe to pump through there for a test?
Just be sure you don't run anything through it that contains methanol.You can use kerosene or diesel fuel or something like Varsol. I had two short pieces of hose- sucked out of a 1L yogurt tub and discharge straight back in again.
It would be best to hook it up to power without the rotor installed - Then you can see the spindle spinning and hear what it sounds like.
I first put mine back together with the intake in the wrong place. This jammed the rotor and the pump just made a humm. It could burn out if left like that for more than a few seconds.
Good Luck!
Great!got it running with the new pump
25-35 gal/hr and 85-105 psi is what they say...Great!
What did that pump cost at Autozone?
Any idea of it specs? (Flow & max pressure)
Why were you worried about igniting gas in the pump when your car is a diesel??25-35 gal/hr and 85-105 psi is what they say...
there is indeed a diesel in my driveway, but the D-jet pump in question is from the 73 450SELWhy were you worried about igniting gas in the pump when your car is a diesel??
BTW - I have an identical '85 300D - Great car!
Mathew - Do you know the model number of the pump and the price that Autozone sells it for?there is indeed a diesel in my driveway, but the D-jet pump in question is from the 73 450SEL
