1 - 20 of 79 Posts
2000 E320
Anyone else besides me have this issue?
The black rubber strip that runs along the bottom of my outer windshield is cracking and falling apart. It looks really nasty. Have any of you ever replaced or needed to replace this rubber strip?
I saw a used E320 on a dealer's lot with that problem. You're right, it looks like Hell, and I wish you luck getting that remedied. It made me want to treat my own rubber right away!
W203, W210 Moderator
E55 ///AMG
I did replaced mine it has small cracks on edge of the rubber.
Its' all one piece, & don't worry it's easy to install & cheap . Here are the part numbers:
210.831.0958 - $20.00
210.831.1058 - $20.00
Goodluck,
JOE55
2000 E320
Goodluck,
JOE55
Thank you so much!
E55 ///AMG
Musikmann said:
Joe, if that is only 1 piece, why the 2 part numbers?
What I meant is the plastic & the rubber are one piece (not seperated) .
2 part numbers beacuse you need left & right side.
Sorry for the confusion I should have explained better (that's why I quoted him on my first reply)
JOE55 said:
What I meant is the plastic & the rubber are one piece (not seperated) . 2 part numbers beacuse you need left & right side. Sorry for the confusion I should have explained better (that's why I quoted him on my first reply)
No problem Joe, and thanks for the clarification.
My Two Left Feet
does that fix help with the wind noise coming from the front? i get wind noise on and off at 75 to 80 mph
2000 E320
Whew, I just installed the new pieces. Not as easy as I anticipated because I couldn't get the screw hole to line up. After playing around with it, I finally got it to fit.
2008 BMW 528i,1999 Lexus 400LS, 2014 e250 BlueTec
Practically all older model of E320, perhaps, upto 2002 will have same problem. I had mine replaced also. E350 is tatally different from E320.
Mercedes E320 2001
Can you post a pic?
Tony
2000 E320
Discussion Starter #12
tonyr69 said:
Can you post a pic?
Tony
I'll try to post pics this weekend.
Just to clarify, most of you would be able to do this with no issues at all. I'm just such a non-DIY guy. I make the easiest things seem so difficult. What should've taken 5-10 minutes to do took me 30-45 minutes. It's always this way for me...
2002 E320 Silver Wagon
Windshield Trim Question
I would like to replace the plastic rubbery trim pieces which are located in the lower portion of the windshield under the wiper. It's the transition piece where the hood starts. Mine is rather sun damaged and starting to crack at the edges. A proper name for this and a parts store online would be much appreciated.
2002 E320 Silver Wagon.
I have seen a used Benz on a lot that was doing the same thing, and it looks really nasty. Try: Mercedes Benz Parts, Mercedes Parts, Accessories and describe it just like you just did here. If they don't have it, call them and ask for Ron (mention Benzworld). He should know where you can get that. Good Luck!
E55 ///AMG
Thanks for posting that Lorenzo here's the info. again..
Goodluck,
JOE55
2004 e320 svr/blk 136k
did you get those parts at the dealer, or did you order online? if anyone has found them online can you hook us up with the link....thanks
Don't feel bad practically 100% of our year cars will have same problem. Lucky that it is easy to replace and not that expensive. I had mine replaced also.
1 - 20 of 79 Posts
