DIY: Blower motor bearing lube and cabin filter replacement, 94-95 Sedan
30748 53
(Quick edit: if you're only replacing the filter, you need not go through this entire ordeal. :) This is much more involved, in order to get to the blower motor. I know a lot of people here know this, but some might not. Same thing for opening the hood all the way. I know most of the regulars here know this, but newbies might not. :) ) --Karl
Last night, I decided to have another go at removing the blower motor from my 1994 E320 sedan. While in there, I was going to replace the cabin filters. Having found there to not be a lot of info on the 94-95 cars, with their different seals at the base of the windshield and slightly different disassembly procedure, I decided to take some pictures and do a writeup. Here goes.
The first thing you'll need to do is park the windshield wiper arm at roughly 45 degrees, so that it is extended. Pull the cover off to expose the single 4mm hex bolt holding the arm onto the mechanism:
IMG_1529 by krshultz, on Flickr
Remove this bolt and set it aside. Pull the wiper arm off of its base:
IMG_1530 by krshultz, on Flickr
Now, raise the hood. Some folks might not know this - there's a trick. You can open the hood to completely vertical. At each hinge, there is a pull tab that you pull towards the center of the car. Start at the driver side. Pull on the tab and lower the hood just enough to allow the tab to move:
IMG_1531 by krshultz, on Flickr
Same thing on the passenger side:
IMG_1533 by krshultz, on Flickr
Now raise the hood completely, and behold the magnificence of your totally accessible engine bay. :) Make sure you have enough clearance up above so you don't dent your grille on the rafters of your garage!
IMG_1534 by krshultz, on Flickr
Remove both pieces of weatherstripping under the hood by the cowl. They just lift right off. Closest to the firewall:
IMG_1535 by krshultz, on Flickr
And closest to the engine:
IMG_1537 by krshultz, on Flickr
Now, remove the cover between the battery and the ECU, OVP, and other electrical components. It lifts right out:
IMG_1539 by krshultz, on Flickr
Your next target is this foam insulation between the back of the engine and the bulkhead. I hate this thing. When my wiring harness was replaced by the previous owner, the wires were routed in such a way that I can't get the wires put behind this, so your wires might be behind it. In any case, this has to come out:
IMG_1541 by krshultz, on Flickr
To do this, you'll first need to remove the plastic trim just behind it. It snaps into place. Here I'm lifting it out of one of the snaps. Look carefully at it and don't yank at it, and it should come right out:
IMG_1542 by krshultz, on Flickr
IMG_1543 by krshultz, on Flickr
IMG_1544 by krshultz, on Flickr
Now the insulation. It's supposed to be held on with four fasteners. My car only has two.:( They are plastic thumbwheels, shaped like a flower, one on each side. I could only get a picture of one. Undo all the fasteners and you can carefully lift it out without tearing it up.
IMG_1545 by krshultz, on Flickr
Now that the foam is out, you can see why we did this. There are two screws holding the center part of the plastic intake box unto the bulkhead. I'm not taking these out yet, this picture is just to show you where the screws are. This is driver side, you can just see what I think is the EGR tube at the lower left corner of the photo:
IMG_1546 by krshultz, on Flickr
1 - 20 of 54 Posts
1994 E320 Sedan
Discussion Starter · #2 · (Edited)
Now you can start removing the big rubber seal at the base of the windshield. Carefully pry up the corner, at the glass, on one side by the A-pillar. I chose to start at the driver side:
IMG_1547 by krshultz, on Flickr
IMG_1548 by krshultz, on Flickr
You can see the channels into which the rubber strip fits to keep water out of places you don't want it:
IMG_1549 by krshultz, on Flickr
And here's why we did this - you have now exposed the screws that hold the plastic drain assembly onto the car:
IMG_1550 by krshultz, on Flickr
Same thing on the other side:
IMG_1551 by krshultz, on Flickr
Take off this screen in the center of the drain assembly, just below the wiper. It lifts right out:
IMG_1552 by krshultz, on Flickr
Now we're ready to start taking stuff out. :) Start with this intake vent, on the passenger side. It is held in with one screw:
IMG_1554 by krshultz, on Flickr
Out it comes:
IMG_1555 by krshultz, on Flickr
And it's gone. :)
IMG_1556 by krshultz, on Flickr
Both sides are slightly different. On the driver side, the vent is held on with two screws, both visible here. It does not come off as its own piece - rather, it stays attached to the larger piece of drain. That'll be obvious in a sec:
IMG_1557 by krshultz, on Flickr
Now that you have both screws out by the wiper, take out four more. This will allow you to remove the entire driver side part of the drain:
IMG_1560 by krshultz, on Flickr
IMG_1561 by krshultz, on Flickr
IMG_1562 by krshultz, on Flickr
IMG_1563 by krshultz, on Flickr
1994 E320 Sedan
Now, carefully pull the white tab that hold the drain together out, towards the front of the car.
IMG_1559 by krshultz, on Flickr
Starting with the outermost piece closest to the fender, carefully lift the drain out:
IMG_1565 by krshultz, on Flickr
Now the second piece. This one may fight you a bit, because it will still have the rubber seal by the wiper arm pressed into it. Be patient with this old plastic so you don't break anything:
IMG_1567 by krshultz, on Flickr
Same thing on the passenger side. Four screws hold this all on, two per piece. Be careful that you don't knock the clips that the screws thread into off - if they fall into the black hole of the engine compartment, they might be gone forever.
IMG_1569 by krshultz, on Flickr
IMG_1570 by krshultz, on Flickr
IMG_1575 by krshultz, on Flickr
Now remove the two screws that hold the center part of the drain/vent assembly in. These are the screws you exposed by removing the hateful foam insulation between the engine and the bulkhead:
IMG_1576 by krshultz, on Flickr
IMG_1577 by krshultz, on Flickr
Be careful and patient, and wiggle the center part out of the car, working around the rubber seal for the wiper:
IMG_1578 by krshultz, on Flickr
IMG_1579 by krshultz, on Flickr
Now, you're ready to remove the wiper mechanism. This is quite easy. It is secured with four 10mm nuts. Two like the one I've got the wrench on in this picture - NOT the bolts. The nuts. You'll see it when you look inside, the two I'm talking about attach the wiper assembly to the car:
IMG_1580 by krshultz, on Flickr
The second one:
IMG_1581 by krshultz, on Flickr
The third one, at the firewall:
IMG_1582 by krshultz, on Flickr
And the fourth one, also at the firewall:
IMG_1584 by krshultz, on Flickr
Carefully lift the entire wiper mechanism up, including the rubber seal. Don't yank on it, because there's a wire attached to the motor:
IMG_1585 by krshultz, on Flickr
Pull this wire off:
Now look - filters!
IMG_1587 by krshultz, on Flickr
Fold down this clip that holds the filters in place. This is the only one that moves, do NOT try to fold down the others, or you will break them:
IMG_1589 by krshultz, on Flickr
On the passenger side, pull out the air temperature sensor:
IMG_1590 by krshultz, on Flickr
There are two filter elements that interconnect with each other. I ended up pulling out the lower one, then the upper one:
IMG_1591 by krshultz, on Flickr
Now you can see your blower motor: :)
IMG_1592 by krshultz, on Flickr
1994 E320 Sedan
Discussion Starter · #4 · (Edited)
The cover for the fan is held on with several metal clips, like this one:
IMG_1595 by krshultz, on Flickr
There are two on each side of the cover, for eight total, if I'm remembering correctly:
IMG_1596 by krshultz, on Flickr
IMG_1598 by krshultz, on Flickr
The blower motor is now exposed!
IMG_1599 by krshultz, on Flickr
The motor is held down by a strap. I marked the surrounding areas with a black sharpie, so I'd know exactly how the motor goes back in:
IMG_1600 by krshultz, on Flickr
Disconnect the two wires, and take note of how they are routed under the strap:
IMG_1601 by krshultz, on Flickr
Carefully lift the motor out of its box. This is where I needed both hands, so I didn't take pictures of the motor out of the car. It looks just like it does, only not surrounded by car. :) I cleaned the bearings, on each side of the motor behind the squirrel cages, with electrical parts cleaner. Then, I used a squeeze bottle, and dribbled some Redline engine oil into the bearings. I spun the bearings a lot to make sure the oil actually got in there. I could already tell it was quieter than before.
1994 E320 Sedan
Now you're ready to put it all back together. Put the motor back in according to the marks you made, and reconnect the wires.
Put the cover back on, paying attention to this wire, which is going to get in your way. You'll want to route this above the box, otherwise, the lid won't go on:
IMG_1605 by krshultz, on Flickr
Put your new filters in now as well. They interconnect, and only go together one way. I found it easiest to connect the two filters first, then put the whole thing onto the blower box:
IMG_1606 by krshultz, on Flickr
Reinstall the wiper mechanism, making sure to reconnect the wiring harness. I found it easiest to use a Gearwrench on the nuts that run parallel to the firewall:
IMG_1611 by krshultz, on Flickr
IMG_1613 by krshultz, on Flickr
This pillar sort of thing is part of the wiper assembly, and it just sits on top of this bracket:
IMG_1612 by krshultz, on Flickr
1994 E320 Sedan
Discussion Starter · #6 · (Edited)
OK, now you have the wiper mechanism completely installed. Make sure you have replaced the air temperature sensor near the cabin filters:
IMG_1608 by krshultz, on Flickr
Now it's time to put the drain mechanism back together and finish up the job. Some of this was harder than I'd hoped to capture in pictures, because I needed both hands. But in any case, reassembly, as they say, is the reverse of removal. Here is the center section of the vent box back in place:
IMG_1614 by krshultz, on Flickr
The next piece I put on was adjacent to the center section, on the driver side of the car. Note that it slides into position using a channel, shown below. If you try to just put it in place, it won't line up, you need to use this channel:
IMG_1627 by krshultz, on Flickr
The outermost pieces (nearest the fenders) feature this funnel shape on the end. This slips into the drain tube that stays on the car:
IMG_1618 by krshultz, on Flickr
The drain tube I'm talking about:
IMG_1616 by krshultz, on Flickr
This is what it looks like on the passenger side when it's all assembled:
IMG_1632 by krshultz, on Flickr
Now that this is in position, get out those white plastic slide-on clips you took off earlier. They lock the inner and outer parts of the drain together. Here is what the clip attaches to:
IMG_1619 by krshultz, on Flickr
Putting the clip on:
IMG_1620 by krshultz, on Flickr
I won't bother to post pictures of me putting in all the screws that hold the whole thing together. Put them in, in the same places you removed them from:
IMG_1631 by krshultz, on Flickr
Once you have the drain assembly reassembled and tightened down, put the foam insulation back in behind the engine. Then, put in the plastic piece that runs alongside it. Finally, replace the two pieces of weatherstripping in the engine compartment. I did not take pictures of this part of the job, mostly because I hate that foam insulation so much that I forgot. But it goes back on the same way it was when you started. :)
For the giant rubber weatherstrip at the base of the windshield, be patient. All around the drain/vent assembly, there is a channel it fits into. Make sure you get this right:
IMG_1615 by krshultz, on Flickr
Another shot of the channels. One channel on the drain assembly, and a second one on the windshield itself. The rubber seal needs to go into all of these correctly, otherwise water could get into your blower motor, your wiper mechanism, and who knows what else, and you will be sad:
IMG_1609 by krshultz, on Flickr
All together:
IMG_1639 by krshultz, on Flickr
Finally, reinstall the wiper arm onto the wiper base and tighten down the 4mm hex bolt. It seems that the wiper arm only goes on one way - if you get it wrong, the hex bolt won't go in. You'll need to press hard, and maybe spread the hole in the wiper arm open a bit with a flat head screwdriver. It is a very tight fit.
Now, clean off your windshield, admire your handiwork, and start the car. Hopefully, your blower motor is far more quiet than it was before - I know mine is.
I hope this is helpful to someone!
E320, 1994, 1995
Very nice and detailed writeup with pictures. Just a few comments.
1. If you go that far removing the blower off, you might want to hose off the condenser to improve the air smell, especially if the filter was never replaced. There might be rotten form from the flap to make stinky smell.
2. If you are simply replacing the filter, you don't have to remove that much, just the right side to get to the filter.
3. To save money, you can recycle the filter plastic frame and make a new filter with home furnace filter.
1994 E320 Sedan
Discussion Starter · #8 ·
Thanks! Those are good catches.
1. I did attempt to clean off the condenser the first time I did this job, though I'm not sure I did as good a job as I could have. When you say "hose off," what do you mean? Hose off with what?
2. That'll be a big help for next time. Somewhere along the way, I read that you want to remove the left side if you're only changing the filter. Not so?
3. I don't think I'm quite that ambitious. :) I found the
. Sometimes, I've found that if you can dig up a part number for something, like "Bosch P3632," I can find it on Amazon cheaper than anywhere else. But their "Make Sure It Fits" feature doesn't always work well. The Mann oil filters I buy there state that they do not fit an M104, but they do.
In any case, I hope the writeup proves useful to somebody at some point. I've learned so much about my W124 on this site, that I felt like I should give something back.
--Karl
E320, 1994, 1995
3. I don't think I'm quite that ambitious. :) I found the filter kit on Amazon for about $26 shipped. Sometimes, I've found that if you can dig up a part number for something, like "Bosch P3632," I can find it on Amazon cheaper than anywhere else. But their "Make Sure It Fits" feature doesn't always work well. The Mann oil filters I buy there state that they do not fit an M104, but they do.
--Karl
You can actually pour water over the condenser and there is a drain underneath. In this way, you watch it really clean. Try a small amount of water first. Yes, you only need to access the filter from the left side as I do it many times already.
--Karl
Great pics...that should help many-especially with the later models.:thumbsup:
The only thing I would amend is your choice of blower bearing oil. I first tried ATF and that stunk in the cabin for a long time. Then I tried 20-20wt small electric motor bearing oil and that too had odor. Finally, I tried turbine oil which was the least objectionable, but I would recommend a 20-20wt (or spec-ed to replace it), synthetic oil for small, high speed bearings. Maybe you guys with the filter and not smelling the bearing oils as badly....:thumbsup:
Go here and then click on the link for impregnated sintered bearings:http://www.nyelubricants.com/applications/bearings.shtml
Kevin
EXCELLENT write-up and details. You are correct, there is very little info on the 94-95 models. I have been needing to do exactly this on my 95 for some time, so this is very helpful. Thank you for your time and effort!
BTW, do you notice any smell in the cab from the oil?
1994 E320 Sedan
Discussion Starter · #12 ·
I don't notice much odor at all. I chose the Red Line engine oil (not ATF) partially because it doesn't have a strong odor. Nowhere near as strong as ATF, anyway.
I'm happy to answer questions about the job, and I'm glad folks find it useful.
E320, 1994, 1995
You live in NC too. Same here (Cary, NC) and with two E320, 1994.
The filter change for e320, 1994-1995 is covered in details by
Bentley's Mercedes-Benz E-class Owner's Bible, 1986-1995. I learned how to replace the filter from this book. Your write up is nice as it goes deeper to the blower motor, which I did it once when I replaced the wiper motor.
The Bentley's Owner's Bible sucks Yak balls....it's nothing but a glorified primer or advanced Owners Manual. Just when the reading starts to get interesting, they stop-'consult with your local dealership' kinda thing. The Mercedes-Benz Technical Companion has more, but not for 124 gassers unfortunately.
Kevin
E320, 1994, 1995
Kevin
I agree in general that Bentley's book is not complete or detailed enough. It does have a few nice sections on cabin filter change, transmission oil change, v-belt change, brake pads, etc. I found myself often using the online index in this forum to do most of the work.
Go here and then click on the link for impregnated sintered bearings:Nye Lubricants, Inc. - Applications: Bearings
Kevin
I like your recommendation on bearing oil. Looking at that site, they have a wide array of oils under the given link. Do you have any insight as to which would be most ideal? Thanks...
Unfortunately, no. My last foray in there finished with the turbine oil. I could offer to call the people at that link, pose as a mechanic and ask their recommendation.
I see what I think would be a good choice on their list, but I'm not positive (need to ask about odor and a car's environ considerations). I also don't know about minimum 'quantities' in dealing with that particular business.
Kevin
Like I said, it's a good 'primer'. You could understand my frustration better (about Bentley) if you've ever picked up their The Complete Official Jaguar E. With books like that, you could keep a car running forever and completely diagnose its ills. Why we can't have books like that for the MB 124, I haven't a clue.....other than the financial gain not being there.:(
Kevin
1994 E320 Sedan
Discussion Starter · #19 ·
I'm pleased to report that the blower is still silent. A welcome relief from the not very loud, but highly irritating, rhythmic squeaking it was doing at low speeds. And I can report that there is still no odor from the Red Line engine oil present in the car - none that I can smell, anyway.
Yep - I'm in Durham. I'm hoping to go to the MBCA tech day at MB of Cary this month, if my director of scheduling (my fiancee) thinks she can stomach it. :)
I should go back and edit the original post, to clarify that you need not do all that work if you're only replacing the filters. I knew that, but figured if I'm going to lube the blower bearings anyway, I might as well throw new filters in too.
I wouldn't take that as a definitive statement on using engine oil for the bearings...some people it won't bother because their sniffers won't smell it. Others it will drive crazy....;)
Kevin
1 - 20 of 54 Posts
