1 - 12 of 12 Posts
2000 MB
Distillation is the boiling of water and getting h20 out of the steam. Is rain water considered distilled h2o ? :bowdown:
W210 Moderator
99 E320
hmm, my initial reaction would be that i wouldn't think so. given envionmental
realities, depending on where you live and the industries surrounding, it would
not take much of a stretch to think that rain can be easily contaminated with
impurities, acid, particulates, etc.
'01-E320 & 02-ST2
Plus one, rain is almost never pure H2O...
02 e320
If you have a non-self defrosting refrigerator or freezer, the frost is the same as distilled water as is the water from a dehumidifier.
Please note bottled distilled water is both distilled and filtered, whereas refridgerator/dehumidifier water is condensation and unfiltered.
The reason behind "distilled" water in coolant is to assure the water it is both ph neutral and free from dissolved minerals/solids.
Not-so-much a problem at all in North America, whereas in Middle East, African, and Asia tap water ph can be really-really whacked out, and dissolved mineral content can be very-very high, both dependent on area, and yet still be be considered "tap" water for that area. Ask the Aussie's or Saudi's who have to replace thermostats and even replace radiators at a rate that would be unacceptable in North America.
RO filtered water is almost as good, and I substitute it for distilled water if necessary; we have a RO filter that supplies a drinking water tap on the sink, the ice maker, and the furnace humidifier.
'01-E320 & 02-ST2
Frost condensate is one thing, but water from a dehumidifier is not potable because it carries pollutants and contaminants from the air. The same things that make it not potable mitigate its use in batteries and the cooling system.
Distilled water is cheap, a gallon every few years for coolant and battery, why all the fuss? Don't buy a cup of coffee one day out of three years and that buys 2 gallons of distilled water -- and that's if you don't get a foo-foo drink. ;)
Take care and enjoy the ride,
Greg
2002 E430 4-Matic
Yikes - don't drink the de-humidifier/air conditioning water. It is probably the dirtest water in the house including the dogs bowl. Think fungus, spores, dust mites, bacteria, and legionnaires disease.
Ditto to some of the others. MB says to use potable water as a diluent for their antifreeze. A tech told me to use distilled and that's what he did. I have never added anything to my battery, but hopefully the guy added distilled on the last B service.
'98 E320 Wagon (non 4matic)
If you have any questions as to whether or not Rain water is distilled, take a sip and see if you taste anything. Not too big of a sip, you don't want to get sick now.
E-ZGO 53 HP., 99 E 430 sport, 04 E55 AMG, 2008 Tahoe LTZ Sold Porsche to Brother
RO water is as good as it gets, only one thing to check before you use it in your cooling system. In the RO process the PH of the product water will be reduced. PH is an indicator of the acid or alkaline condition of water. The pH scale ranges from 0-14; 7 indicates the theoretical neutral point. Water with a pH value less than 7 indicates acidity and tends to be corrosive water.
So get your test strips and neutralize your coolant water with soda before you mix it with coolant. And never go stronger than 50/50 antifreeze / water mix.
1 - 12 of 12 Posts
