Hi,
I have a problem with my s500L w220 RHD year 2000. The problem started with airmatic when I was driving in germany on autobahn and temperature has dropped below -3C degrees. I received a message on dashboard CAR TOO LOW PLEASE STOP. Message disappeared as soon as I raised the car with the button to lift the car up. Now after a few weeks I am back in UK and receiving Display defective ESP visit workshop ABS light up and sometimes I get a CHECK ENGINE message when drive around for some time.
I have disconnected ESP PSL BAS module, cleaned the connectors, put it back in and still the same.
I cleaned OBD errors and re-run the report;
BENZ/Vehicle Select/S(220)/Up to 08/2002/Gasoline Engine/220.175 - S 500 / S 55 AMG/Quick Test/
Total Number :41 CHASSIS
MODEL
TCM - Transmission Control Module
038
CAN Communication With The Traction System Is Faulty.
134 Resistance too Low
CAN Communication With The Traction System Is Sporadically Disturbed.
ESM - Electronic Selector Module Fault | (1)
P1876 State: Current
Communication With Traction System CAN BUS Interfered.
Suspension Fault | (2)
C1026-008 State: Current and Historic
Fault In CAN Communication With Control Unit N47-5(ESP, SPS [PML] And BAS Control Unit). C1026-128 State: Current and Historic
Steering Angle Sensor Is Not Initialized.
220
220.175 - S 500 / S 55 AMG Fault | (2)
OCP - Overhead Control Panel
B1881
SR Is Not Normalized.
HRA - Headlamp Range Adjustment
B1041
Fault In CAN Communication With Component N47-5(ESP, SPS And BAS Control Module).
B1613 State: Current and Historic
Component E3e2(Left Taillamp And Parking Lamp) In Module E3(Left Taillamp) Is Faulty. B1615 State: Current and Historic
Component E4e2(Right Taillamp And Parking Lamp) In Module E4(Right Taillamp) Is Faulty.
Fault | (1)
Fault | (1) State: Current
REAR SAM - Rear Signal Acquisition And Actuation Module
Fault | (2)
D2B - COMAND Or AUDIO
Fault | (1) State: Historic
B1769
Remote Signal Processing Internal Fault
DCM_FR - Door Control Module Front Right
B1521-005
Exterior Mirror Adjustment And Heating : The Mirror Heater Has Short Circuit Or Open Circuit. ESA_FL - Electric Seat Adjustment Front Left Fault | (1)
B1854 State: Current and Historic
Fault In CAN Communication With Control Unit ICM.
ESA_FR - Electric Seat Adjustment Front Right Fault | (1)
AC - Air Conditioning Fault | (1)
B1269 State: Historic
Communication Fault Of AC Bus With Control Unit B31/1(AAC Multifunction Sensor)
I also purchased another used ESP PSL BAS Module same serial and model number but get same output on obd.
MODEL
038
220
B1881
B1041
Fault | (1)
Fault | (2)
B1769
B1521-005
