v220 ambiente
Hi all
Has anyone taken apart a door mirror? Mine is a v class type. It had a whack while parked, and was knocked forward. The only obvious damage was a crack in the trim around the glass. I super glued this but the mirror now only moves in one direction. I suspect a broken wire or connection. Any advice about how to get into the works greatly appreciated. Thanks
G
Vito 111CDi 2004
I have not taken a v class one to bits but the vito ones come apart really easily. The mirror should just pop out as it's held on 4 lugs allowing you to have a look at the bits beneath.
v220 ambiente
Hi adumuk
Thanks for advice. Will give it a go. If the glass breaks the replacement looks quite cheap anyway.
G
