Yesterday I installed a new head unit in the SL (after returning one that didn't work properly).
The wiring in the dash is a bit of a mess, but originally using a multimeter I pretty much nailed down the important wires. A blue wire supplied the constant 12V, and I had an earth and a switched power supply.
In the beginning all was well but at some stage during the install the blue wire ceased to give any power at all.
What I'm wondering is what might have caused this? Also if I can't get power from the wire, is there any other source of 12V under the dash that I can use to keep the stereo powered. (Currently I have the switched power only that causes the memory to blank every time the car is switched off).
And while I'm here
, my antenna connection has two wires (black and red) 'stuck' to it - what are these? I don't think I used them before when I had the power antenna working - and as it currently isn't I guess I need to find out...
Any help would be good!
And while I'm here
