1999 ML 430
My CEL light is on. Is there a way to disable limp mode so I can get the car 36 miles to the shop? I know the problem is the ECU or the conductor plate if that helps. Turning the car off and on does not work. Thanks for any input.
JD
1999 ML 430
Not that I know of.
I guess I would need a read out of the codes before they were cleared so I could provide them to the indy who is 36 miles away.
90 300E
i believe the scanner might do the trick but you wouldnt want the cel light to come on on the 36 mile trip. your best bet is having it towed....because the light can come on again in the middle of your trip and than your screwed...its your call
GJ
