1 - 1 of 1 Posts
I had a bearing failure in the differential on my C180 Esprit (manual) and will likely have a seasoned professional replace the bearings.
But in case there is something else broken (have not yet opened it so no way to tell the condition of the gears), which other diffs are interchangeable?
It is the model with ABS sensor in the differential, 3.91 gearing obviously.
If I fit a diff with different gearing, is it possible to adjust speedometer in software?
1 - 1 of 1 Posts
