Definitely not.
It's a pipe thread (tapered), so no sealant.
Some recommend a layer or two of teflon tape, helps make it easier to remove the next time.
Remember to remove the fill plug before you remove the drain plug.
Good luck.
Remove the fill plug first, because if you do the drain first, and find that the fill cannot come off, you have a problem.
Teflon dope, find in Home Depot plumbing is better than tape on several fronts.
It will not end floating inside the case to start.
Notice the relatively low torque for big plug. Lot of mechanics like to overtorque them and you need really long bar to break them loose.
I don't know of anyone who was ultimately unsuccessful. There have been some who gave up on it as a DIY because it was "too tight" and they didn't want to damage anything, so they took it to have it done; it came out, it just wasn't their doing...or undoing.I see. Wonder if anyone cannot actually remove the plug for some reason? Any experience to share?
Definitely not.
Good luck.
Only if there is lots of rust on the surface.Would it be sensible to spray some PB or WD40 at the fill plug to make it easier to remove?
