Hey gang, long time.
On our '93 190 2.6 the left rear window goes up to about 1' from closing all the way. It then goes back down all the way. Certainly doesn't appear to be a motor issue; regulator issue or one of the plastic white gear-like pieces? I searched 'windows' forum and did not find this particular issue to exact.
Best.
Sounds like it's your regulator.
Sounds like it friend. After my post I went back and now pressing the button you can hear the motor 'whirring' and trying to catch something now it doesn't move at all. At least its in the mostly-closed position until I can get her serviced.
Either a stuck pulley, jammed cable or a broken guide rail
won't know for sure until you take it apart and look at it.
Plan a trip to your local JY for a used unit.
IR MODERATOR
common issue it was recently posted.
