87 Mercedes 190D 2.5 Turbo, 85 VW Golf Diesel, 86 Chevy Celebrity Eurosport, 91 Chevy S10 Blazer
This has been a conundrum for me. My 87 190D-Turbo has no keys (i lost them, stupid me). I went to the salvage yard and grabbed an ignition with key from a 190 2.6. From what i could see there were no differences except for a couple of vacuum lines that attached to the original. I transferred those over and rehooked it all back up but it wont start. Won't even crank. All the lights come on except the glow plug light. Is there a difference between the gasser and diesel ignitions? All the numbers on them matched, they look exactly the same, but i've got nothing. I bow to superior knowledge here, this is my first Merc. :bowdown:
Thank you for any info ya'll can provide!
'98 E300, '10 GL350 Bluetec
Those vacuum lines are to actuate the stop lever on the injection pump. In your case the car should crank over.
If I were you, I would go to the dealership with proof of ownership showing the car's VIN and they will make you a new key. Then you can use the original ignition switch and the key will work with all the locks.
1987 190D 2.5 Turbo, 1999 Mercedes Benz C230 Kompressor, 1986 190D 2.2 397,000miles
You actually could have just went to the Mercedes place ( i did) and give them your vin they would have gave you a new key without the other one. I thought they would have to have a key, but they do not.
