On my primary filter I am getting little black particles in the filter and they are clogging my filter. I have taken the fuel tank out and had a radiator repair shop steam it out. It was dried and new filters were put on. It is a diesel and I ran a diesel purge thru the engine. Where would these little black particles be coming from. They build up within 150 miles??? Any help would be appreciated.
Have you changed all your fuel hoses lately? Sounds like one is falling apart, its a cheap fix, and should be done every few years anyway
Yeah, like torq, the only thing I can think of is the rubber fuel lines between the tank and primer pump may be deteriorating.
Replaced the hose from the steel hose to the primer bulb and was able to drive 250 miles home without a breakdown. Are there lines coming from the tank under the car that should also be replaced. I will replace the cigar hose as soon as I obtain one. Thanks for the info. hard to believe that little 3 inch hose could cause all the problem.
Replaced the hose from the steel hose to the primer bulb and was able to drive 250 miles home without a breakdown. Are there lines coming from the tank under the car that should also be replaced. Yes I will replace the cigar hose as soon as I obtain one. Thanks for the info. hard to believe that little 3 inch hose could cause all the problem.
Cigar hose, pricey, can use a regular fuel line.
