2008 GL320 CDI 2008 ML320 CDI 1984 Euro W123 300D
Hello all,
I have tried the links in the sticky for plastic diesel fuel lines so I can get the part numbers but the sticky's don't work for me. Does someone have the part numbers for the required lines and also for the SOV oring or a working link? Thanks in advance.
Dan
Discussion Starter #2 (Edited)
I can find four part #s online but
I see six clear plastic lines on the pump and filter, are a couple of the fuel lines used twice? I found four part #s online, I see six clear lines on and around the pump and filter.
The part numbers I found are; EDIT (these part numbers are from an after market supplier, parts geek I think)
w01331717621
w01331717622
w01331717623
w01331717624
Which of these if any are use twice?
Thanks in advance.
Dan
1959 220S cabriolet, 1983 240D original owner, 1999 E300 turbo diesel, 1988 560SL, 2003 SLK320
Dan - sign up for the EPC - it's free. You can look up those part numbers all day long on there.
EPC-net Online
I posted the part numbers for 5 tubings long time ago, but the search on this forum has limited time frame and I can't find it myself.
I did not replaced the tubing coming down from thermostat since it has one end of eye connector and those last forever.
Order 5 tubings and don't forget about SOV oring as well as prefilter oring.
Russian site is good, but start with VIN
http://www.neoriginal.ru/cat/mb/
Thanks sokolokk and Kajtek1 I got....
the part numbers from my local dealer, and, I found they have an online discount parts service (mercedespartsforless dot com) all six fuel lines including the superseded one with the banjo bolt and washers came to @$55.00 and change not including shipping which I won't need, very reasonable.
The six Mercedes part numbers are;
605 070 14 32
606 070 05 32
605 070 07 32
605 070 08 32
605 070 15 32
606 070 04 32
Hope this will help others with this engine and fuel system.
Dan
I vote to put it in the stickies so it won 't get lost again.
$55 is really good price. I paid about $70 for 5 tubings, so how about adding dealer web address?
