w210 E420 2000,w124 1992 300e,w123 1979 240d,mitsubishi 1991 VR4
i just got a 1979 24d diesel , is it ok that i used a diesel fuel additive to clean its fuel lines & carb? the idel is a little bit rought
any recomendation or tips ?
1990 500SE
You do not really need any additives if you use a good quality name brand diesel fuel. If you want there is one that some forum members use, it's called " Seafoam ".You can buy it at NAPA . Just add it to about half a tank and then drive for awhile and then refuel. You just need to do this once a year.This is to clean up your injectors and not your " carb "
Also if your diesel is running rough there might be other causes and the additive may not solve your roughness.
1979 280CE
The additive may have clogged up your fuel filters, I would replace them both and see if it solves your rough idle.
