I have a 190D that makes a claping sound, mostly whyle idle. I was told to be normal, something to do with the hidraulic injectors. Now, my 250D, 5 cylinder multivalve, is also starting to do the same noise. That makes me wonder if it is in deed normal... If it's not, what is causing it? I what that smooth engine noise back again!
I wonder if there is a problem with the IP delivery valve spring or seat (copper washer). Have you replaced the delivery valve seals lately? Some people have reported that they get that clapping after replacing the seals, but they drive it hard and the noise corrects itself after about 100km.
clapping sound at idle
agree, most likely hydraulic lifters - When was your last oil change and are you using the correct grade?????????
