1 - 20 of 21 Posts
Hi,
I have a 1988 560 SL with 34,000 miles and need some advise diagnosing a rough idle issue. It's not terrible, but it does distract from the driving experience. The car has California emissions and is in pristine condition.
Besides the rough idle. The idle speed fluctuates between about 600 and 700 RPMs in about 1 second intervals. The roughness continues as the throttle is opened. At about 1100 RPMs it either goes away or becomes unnoticeable.
I had a tuneup done last summer. The fuel filter and spark plugs were replaced. The mechanic noticed the rough idle and suggested disconnecting the O2 sensor. He said this is a common practice on these cars. I didn't really want to do this, but since it is easily reversed, I went ahead. As I have done more research, I've come to believe this is a bad practice.
With the O2 sensor disconnected, the idle was silky smooth. I began to notice a fuel smell whenever I would come to a stop. I believe the car was running too rich so I reconnected it and cleared the OBD alert.
With the O2 sensor reconnected, the rough idle returned immediately.
Any suggestions for where to start my diagnosis? Any help would be greatly appreciated.
Thanks,
Jay
Hi,
Thanks,
Jay
I question that mechanic's intelligence. Disconnecting the o2 sensor forces the car into full enrichment hence the smell. This isn't a problem if you don't mind destroying your catalytic converter and reducing the life of your spark plugs.
Given what you've posted, it sounds like there might be a slight air leak towards the top of the engine. False air into the intake causes all sorts of mischief.
A smoke test will reveal such leaks.
The next step if no leaks are occurring would be to investigate the idle management system. These do go bad causing weird or high idles. You can rebuild the idle control relay by reflowing the solder and capacitors.
I would look for leaks first given the age of the vehicle and low miles.
I have a 1986 560SL that idles a little rough but accelerates silky smooth.
Still have it even after replacing my O2 sensor.
My old O2 sensor was sorta a hack job, so I replaced it with a $20 O2 Sensor off Ebay.
I've done a lot of tinkering trying to fix this idle.
Might try disconnecting mine, and might even purchase an OEM O2 sensor to try.
BTW, whats your fuel economy with the O2 sensor disconnected?
Thanks for the reply.
I haven't paid attention to the fuel economy. I don't put many miles on the car and only fill the tank with enough fuel to last a few weeks. I'm trying to keep old fuel out of the system.
I suspect my O2 sensor is working properly and this is probably a vacuum leak.
Jay
Good luck, please let us know what you see!
Also, apologies for my terse reply. I've heard and seen all sorts of nutty things before and hearing stuff like that makes me go:
No worries. I didn't take your reply as terse. BTW, I've changed mechanics because of this issue. I don't want bad mechanics touching my SL.
Jay
Smoke Test
I finally got around to doing a smoke test on the vacuum system today. I definitely have a leak.
I can't see exactly where the leak is, but smoke is coming from below the idle control valve. It is something around the front of the intake manifold.
Any ideas what it might be before I start taking things apart?
Thanks,
Jay
I would say the AFM booth, the vacuum connections on the throttle body or the manifold donuts.
The vacuum connections are easy to check by just looking down and fidle around a bit.
With a good flash light and a "dentist mirror" you should be able to see if the AFM booth is well seated on the throttle body by the inside.
The donuts are a larger operation as the complete intake manifold needs to be removed.
Good luck:thumbsup: B
Good luck<img src="https://www.benzworld.org/forums/images/smilies/thumbsup.gif" border="0" alt="" title="thumbsup" class="inlineimg" /> B
X2
I'd also replace the lower plenum donuts , the gaskets that mount the intake to the plenum, and all of the plastic components that sit down there.
Lot of "while you're in theres" worth doing. I did the job twice because of a denseness in my cranium. The issue ended up being bad injectors.
Discussion Starter #11
Thanks for the reply. I ordered some inspection mirrors today. It looks like there is a bunch of stuff to disassemble to get to any of these parts. Hopefully it's not the manifold donuts.
Jay
Discussion Starter #12
Good thought. For whatever I have to disassemble, I'll proactively replace as many plastic and rubber parts as I can.
Jay
Don't want to hijack the thread, but has anyone changed the AFM boot before? I am currently in the process of changing mine (on a 380SL) and am struggling a bit with it. I have the old one removed, but the new one doesn't want to stay in place while the two halves are tightened.
Derek
Derek
Hello Derek,
I have. Did you purchase the updated flange for the boot?
This flange is required (1161410445). Don't try and reseal everything back up without getting it!
Damn, nope! Well, there's another $150 gone. At least that explains why it wasn't working. The sad part is I spent quite a few days getting the old flange cleaned! (Bangs head on desk and whimpers softly).
Thanks.
Thanks.
I know those feels bud. Been there done that!
Here's an ebay auction for a used one:
https://www.ebay.com/itm/86-87-88-89-Mercedes-Convertible-R107-380-450-560SL-Air-Flow-Sensor-Flange-OEM/283515513731?epid=1923318377&hash=item4202d76b83:g:YMAAAOSw0tNdAnpZ
It's made of solid metal so no harm in getting a used one.
A friend of mine had one smoke tested and it turned out to be a worn throttle shaft. He had the throttle body replaced.
He was describing it in such detail I thought he did the job himself so I told him I was impressed. Then he told me it really wasn't that hard at all. All he had to do was sign a check.
X2
Those require removing the intake manifold (Here be Dragons). But yes if you have to remove the intake get it all, including all the broken intake manifold bolts.
Discussion Starter #20
An update...I have performed the smoke test three times:
The first, I had smoke coming from around the throttle body, but could not see exactly where.
The second, I had smoke coming out of the ERG valve.
The third, I had smoke coming from both places.
I probably just didn't notice all the smoke in the first 2 tests.
I tried to remove the EGR valve and see if I could get it working. I got all the nuts off, but I could not pull the EGR valve from the pipe. It turns freely and moves in and out a few mm, but doesn't come off.
Any ideas what is needed to remove the EGR valve from the pipe? I don't want to break that pipe. It looks like it would be a bear to replace.
I can't see where the smoke is coming from around the throttle body. I've tried an inspection mirror, but it is very tight in there.
I'm trying to decide if I want to take on the job of disassembling everything necessary to get to the throttle body. I may just take it to my new mechanic and be done with it.
Also, I used the vacuum line to the brake booster to do the smoke test. I found brake fluid in that line. I think that means I need to replace the master cylinder or booster or both.
Thanks,
Jay
1 - 20 of 21 Posts
About this Discussion
7 Participants
okyoureabeast
Mercedes-Benz Forum
Full Forum Listing
