1 - 9 of 9 Posts
2006 G55k - garage queen, 2010 G55k -daily beater
Can anyone give me in depth instructions on what exactly need to be relocated. There is a pump/vacuum of some sort right behind the drivers side head light. How and where are you relocating this thing?
Discussion Starter #2
Well after a good nights rest I decided to tackle this. What I did is somewhat temporary until I can have a mount fabricated. I unbolted all three bolts on air pump, disconnected the air tube and wiring harness. From here i bent the mount slightly forward allowing the Depo lights to fit. I hooked the pump back up as normal and gently placed it behind the lights and zip tied it in place. I will have a mount fabricated and fixed to the body so the air pump can be 100% secure. I will have this done when I install my Brabus LED DRL's installed.
1 - 9 of 9 Posts
