1 - 9 of 9 Posts
1986 420 SEL
I have tried several mono valves for my heater in a 1986 W126. None seem to last or won't work at all. I have resorted to removing the bottom of the solenoid plunger to use in the winter but that only results in heat all the time. Where can I get a reliable replacement valve.
· Outstanding Contributor
'17 GLS450, '14 GLK250 "Grandpa's Roadster" Project Car, 350SDL (Sold)
There's been about 5 million words written on monovalves. I suggest you use the search function and read up on it. There is no simple answer, unless you want to spend a lot of money.
I'm sure you're happy you asked for help so the Mercedes Gurus could shame you
OP: Hope you didn't get scared off. I just believe it's better to educate yourself then pick the right solution for your situation. Here's a good place to start:
Part 2:
1 - 9 of 9 Posts
